Thread: PCV issues......
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Mercer, Pa
    Got a compressor? Blow are in passage. It is routed through super charger to the front left of super and from there into front PCV hole in manifold. If it does not seal manifold vacuum and boost pressure will go to crankcase.
    Does it seal to manifold?
    Mercer, Pa
    Does that slot get sealed off by manifold? Or has to much material been removed from LIM?
    Mercer, Pa
    He doesn't have to have your ported gen 5 blower for the intake. What are you getting l67 or L32 intake? Either will work bit the inlet is a little bigger on L32 and will flow a little better. Gen 5 works on L67 but gen 3 doesn't work on L32 manifold.
  4. #24 Re: PCV issues......
    Rollin...also ..if you need a manifold. I have some laying around.
  5. #25 Re: PCV issues......
    Waukesha, WI
    am i going to be alright with a IC on your old LIM?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  1. TCS/ABS issues?
    By Iced Iridium in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:51 PM
  2. Just got a 98 GTP has issues lol
    By beno420 in forum Introductions/Noob Questions
    Last Post: 05-17-2011, 10:14 PM
  3. tcs issues still
    By LAIDBACKLUKE in forum General Tech Discussion
    Last Post: 05-11-2010, 01:54 AM
  4. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
  5. BOV issues
    By rodman in forum Turbo
    Last Post: 03-27-2009, 09:00 PM
