Thread: Help...not getting fire
Results 1 to 20 of 82
  1. #1 Re: Help...not getting fire
    I have the ability to change usernames. I'm getting very close to changing yours for a giggle.
    Why did you say you think the wiring is 97 if you then say other things.
    Read the below twice:
    I can easily help you. However you are currently standing in the way of me helping you. Answer those four questions and I can help you. This is really not a hard issue to solve. Right now the biggest issue I am having in helping you is getting the information needed to help. Answer the questions, clearly and directly. Thanks
  2. #2 Re: Help...not getting fire
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    What year is the pcm?
    The PCM is the same one that has always been in the car, it is a 2000
    What year is the main engine wiring harness?
    I'm still not clear as to what you mean by this( I am trying to get you the answer you need though), is there a harness that is actually in the engine itself? From what I was told all of the wiring that was attached to the original 2000 motor remains in the engine bay and is being used for the 97 motor.
    Are the plugs getting wet with fuel?
    The engine is getting fuel
    If one of the plug wires is removed at the coil pack and the car is turned over...is there a spark jumping around?
    There is no spark jumping around when the car is turning over and a plug wire is removed from the coil pack
  1. my ass is on fire
    Last Post: 07-02-2011, 05:06 AM
  2. #1 Cyl Mis Fire
    By 88ironduke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:58 PM
  3. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
  4. Mis-Fire #5
    By gtbeach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 11:39 PM
