Thread: supercharger maintenance?
Results 1 to 3 of 3
  1. #1 supercharger maintenance?
    Vail, CO
    i already have an egine code with the boost control solenoid. ill get to that when i can. the little 3-hole disc inside has loose holes making a small rattling sound at idle. are those 2 issues the same thing?
    what else needs to be done to the supercharger to properly maintain it? its at 146k right now, at what point do i need to change the sc oil?
  2. #2 Re: supercharger maintenance?
    Houston
    The S/C is a closed system, the oil is supposed to last up to 200K. Changing the oil, is really for peace of mind. As for the "3-hole disc" (coupler), if its rattling, replace it. If you do that, you're gonna need to replace the oil too. You shouldnt have a boost control solenoid unless you were turbo.
  3. #3 Re: supercharger maintenance?
    Lima, OH
    When I did my supercharger I completely took it apart and greased the needle bearings inside the housing then put it all back together. I installed a new green coupler with mew oil but also did a paint job while it was apart.
    1/8mile: 9.354sec@77.026mph the best 60ft: 2.211sec
    1/4mile: 14.2889sec@93.16mph the best 60ft: 1.9668sec
  1. 75k Maintenance?
    By develand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 01:47 PM
  2. supercharger Maintenance
    By shart in forum General Tech Discussion
    Last Post: 11-04-2011, 03:25 PM
  3. Doing some maintenance
    By GoldGTP in forum General Tech Discussion
    Last Post: 03-17-2011, 01:39 PM
  4. car maintenance
    By cerick08GP in forum Off Topic Discussion
    Last Post: 11-29-2010, 02:33 AM
  5. maintenance fun
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 12:21 AM
