Thread: No Start-Fuel pump?
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: No Start-Fuel pump?
  2. #22 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    ok thanks for all the help i listened for the whine and i do remember hearing it before when i think about it and now nothing. one more question...Do you guys think this 99 1999 Pontiac Grand Prix Fuel Pump - Fuel Delivery - Action Crash, Airtex, Autobest, Bosch, Delphi, Denso - PartsGeek (the $110 one) would be ok? im kinda broke right now
  3. #23 Re: No Start-Fuel pump?
    if you just swap the pump in the sending unit its under 50 in most cases. napa should be able to get the pump by its self or at least get you a part # to go by.
    like this, this may even work for your car. keep shopping they get cheaper. 98 99 00-05 Pontiac Grand Prix Bonneville fuel pump NEW on eBay!
  4. #24 Re: No Start-Fuel pump?
    heres the same pump 53 before shipping i guess. T-Rex Auto Parts: TREX30-760 Electric fuel pump kit fits GM
  5. #25 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    Thanks for all the help. you guys really know what your talkin about
  6. #26 Re: No Start-Fuel pump?
    if your gas gauge works theres no reason to spend all that money, search you tube on how to change it, its super easy.
  7. #27 Re: No Start-Fuel pump?
    Mar 2012
    Hays, KS
    Why do ya say if the gas gauge works, no reason to spend all that money?
  8. #28 Re: No Start-Fuel pump?
    Quote Originally Posted by XtrmGTP View Post
    because the gas gauge sending unit is part of the fuel pump. if your gas gauge works why pay for a new one,( up to 200) when just a replacement pump is 50 or less.
  9. #29 Re: No Start-Fuel pump?
    Troy OH
    there's a little float on a resistor hanging off the pump assembly. you can take that off and put it on the new pump to save moniez.
  10. #30 Re: No Start-Fuel pump?
    Mar 2012
    Hays, KS
    I have a 99GTP that won't start. I turn the key on and don't hear the fuel pump prime and the gas gauge reads full, doesn't move. The car had 1/4 tank the last time it ran. That's why i was asking...
  11. #31 Re: No Start-Fuel pump?
    in your case i would get the whole sha bang, new replacement pump.
    but i would do some checking around before i just went and spent 200 on a pump.
    check fuses, resistor, check for power at the pump, with the key turned to run.
    if all that checks out then get a new pump.
  12. #32 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    In my case I'm 98 percent It's the pump but I spent $110 on the whole assembly cuz i checked everything else and since It's my dd and cheaper to get parts off the internet for the most part It's just worth the money to not buy a whole bunch of little parts when your not sure if it will do the job and this way It's done and over with. Plus then you ain't gotta worry bout other parts of it goin to $hit on you in the middle of no where
  13. #33 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    I got my fuel pump replaced about a week ago and the next day i was on my way to work and the check engine light came on. I just got it checked today at orielly's and the code was p0446. i had them delete it and im just gonna wait and see if it comes back on. The priint out i got says it could be fuel tank pressure sensor out of calibration. could that be just because i replaced it the computer had to relearn?
  14. #34 Re: No Start-Fuel pump?
    Troy OH
    isn't that a code for an evap leak?
  15. #35 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    It also said somethin about that...what would that mean?
    and the code hasn't come back....at least not yet
  16. #36 Re: No Start-Fuel pump?
    Troy OH
    you have air entering your evap system. when gas in the tank turns to vapor, there's a vacuum line that goes to the intake manifold that pulls all those vapors into it and, since it's just gasoline, it burns. it's a calibrated system, and the car doesn't like when there is air in it. it's possible that the code hasn't come back because the conditions for running the diagnostic test haven't been met. it's not a huge deal, the car can compensate for it, but it sets a check engine light because the EPA doesn't like raw fuel vapor being dumped into the atmosphere. when they changed your fuel pump, they could have damaged the vacuum line, or just not hooked it back up
  17. #37 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    I replaced it which one is the vacuum line? I don't think I damaged anything and I know I got everything hooked back up right
  18. #38 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    Would it hurt my fuel mileage or make my car run lean or rich?
  1. grand prix wont start, fuel pump is good.
    By 1986c10 in forum General Tech Discussion
    Last Post: 12-19-2011, 08:51 PM
  2. No start: Fuel pump or resistor perhaps?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:43 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Car will not start, possible fuel pump fail
    By osbornb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2010, 12:01 PM
  5. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
