Thread: No Start-Fuel pump?
Results 1 to 20 of 38
  1. #1 No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    So i got a 99 gtp and and the last day or two it has been more difficult to start and it was taking longer. at first i thought it might be the starter going out but i went up to orielly's today i went to back out and i got about halfways out of the parking stall and it died and now it wont start. I think it might be the fuel pump cuz its not a fuse and i checked the box inside the engine compartment too. My car has 135,000 miles and i was wondering is this normal for one to go out this soon/should it have gone out a while ago? On a scale of 1 to 10 how dificult is it to replace and where can i find a cheap oem replacement? they wanted $250 for one at oriellys. All help is appreciated
  2. #2 Re: No Start-Fuel pump?
    Charles City, IA
    Do you have fuel pressure? Do you have spark?
    SMGPFC Two Nipple General
  3. #3 Re: No Start-Fuel pump?
    Could be the fuel pump resistor. bend the 85 or 86 pin out and try to start it. Also try starting it with starting fluid.
  4. #4 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    Btw its my only car and i dont feel like riding my bike 18 miles one way to work so the sooner the better
  5. #5 Re: No Start-Fuel pump?
    Jacksonville, Fl
    you could check the fuel filter. see if you can blow through it.
  6. #6 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    how do i know which pin is which? and im pretty sure i have spark based on the way it died but im gonna check for pressure...where would be best to check?
  7. #7 Re: No Start-Fuel pump?
    spray starting fluid in the intake and if it starts its a fuel issue and not a spark issue
  8. #8 Re: No Start-Fuel pump?
    Charles City, IA
    Check at the shrader port on the fuel rail, starting fluid is not a good idea because you have to spray it on the maf.
  9. #9 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    not sure what a shrader port is can you explain it?
  10. #10 Re: No Start-Fuel pump?
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Its on the fuel rail and it looks like a Valve stem cap on your tires
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  11. #11 Re: No Start-Fuel pump?
  12. #12 Re: No Start-Fuel pump?
    I dont see anywhere that anyone said FPR yet.
    Pull the vacuum line off the FPR, if fuel comes out that may be a cause of the problem as well. If its completely shot, the can cant hold fuel pressure.
    Just another thing to check.
  13. #13 Re: No Start-Fuel pump?
    Troy OH
    kick the gas tank a couple times. that's free and easy, and no lie, i've done it in a parking lot and in the shop to start cars and isolate the fuel pump.
  14. #14 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    as for the shrader port would there be one right in front and middle that has a little twist on cap? and im guessing i would need a pressure tester? and i dont think it would be the filter cuz some would still get through it just wouldnt be very responsive. As for the resistor if i bent that out could i bend it back without it breaking? and what would it do to bend it out? and what is the fpr valve? where is it located and what does it do?
  15. #15 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    what do you mean isolate the fuel pump?
  16. #16 Re: No Start-Fuel pump?
    shrader valve yes your on spot there. open the top under it looks like a tire air stem, put a rag over it, and push the middle in with a screw driver, if its got pressure gas will spurt out of it.
    the relay pin, yeah it should bend back .
    fpr= fuel pressure regulator.
  17. #17 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    thanks where is the fpr and what does it look like? btw thanks for all the help guys. im a rookie when it comes to my grand prix
  18. #18 Re: No Start-Fuel pump?
    Jan 2012
    Abilene, KS
    checked the shrader port and no pressure. is that a pump? and the filter is in the tank right?
  19. #19 Re: No Start-Fuel pump?
  20. #20 Re: No Start-Fuel pump?
    sounds like you have no fuel pressure.
    fuel pump is easy, you have a door in the back of the trunk under the rug.
  1. grand prix wont start, fuel pump is good.
    By 1986c10 in forum General Tech Discussion
    Last Post: 12-19-2011, 08:51 PM
  2. No start: Fuel pump or resistor perhaps?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:43 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Car will not start, possible fuel pump fail
    By osbornb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2010, 12:01 PM
  5. 2000 gtp fuel pump wont run after start up
    By look out in forum General Tech Discussion
    Last Post: 05-16-2010, 05:47 PM
