Thread: Harmonic Balancer Bolt Removal
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #1 Re: Harmonic Balancer Bolt Removal
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Quote Originally Posted by 99prixgt View Post
    ive used the starter trick 2wice, both worked like a charm, i had my ignition wires off the spark plugs and fuel pump fuse pulled, and of course s/c and serpentine belt removed
    Could I just pull the ignition wires off the distributor?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Harmonic Balancer Bolt Removal
    yeah just make sure you know which ones go where.
  3. #3 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Got it off redneck version worked like a charm! Thanks guys
  4. #4 Re: Harmonic Balancer Bolt Removal
    Rednecks FTW!! LOL
  5. #5 Re: Harmonic Balancer Bolt Removal
    Jersey
    246 -rear head
    135 -front head
    (looking at the engine, from the front, like if you opened the hood)
    i got that **** memorized from doing spark plugs all the fuggin time lol
    16' wrx sti- stock
  6. #6 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Final thought, when putting all this back together I didnt think about putting on any lock tite or anything on the balancer bolt. I just impacted it back on. Should I pull it again and put some sort of lock tite on it?
  7. #7 Re: Harmonic Balancer Bolt Removal
    Apr 2009
    Fort Worth TX
    GM ACDelco - Crankshaft Bolt #GM-24504736
    If you used a new TTY bolt
    : 111 ft/lbs + 76 degrees angle torque up to 10/98
    111 ft/lbs +114 degrees angle torque 10/98 and up
    If you reused the old bolt just torque it to 111 ft/lbs because it has already been stretched. Put some moly grease on the friction surfaces. That's what I did on my last rebuild and no problems yet.
  8. #8 Re: Harmonic Balancer Bolt Removal
    I've never put locktite on the HB bolt, and I reuse the stock bolt all the time.
    After putting the balancer on by hand and getting it to engage the key in the keyway, I zip that bolt on with my impact. Never an issue..never a worry.
  9. #9 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Thanks Bill, just thought id ask cause ya never know!
  10. #10 Re: Harmonic Balancer Bolt Removal
    Mar 2012
    michigan
    try hitting the end of the bolt with a smaLL SLEDGE the somethimes jars the lock tight and breaks it loose
  11. #11 Re: Harmonic Balancer Bolt Removal
    Sep 2012
    Savannah GA
    Hi Guys, I'm getting ready to do a crank position sensor job on a 3.8.
    Could someone describe to me how to lock the flexplate to hold the crank still while loosening/tightening the harmonic balancer bolt? Thanks!
    (side note, I too have used the "redneck method" for loosening the bolt on a hyundai, but I don't have a good method for tightening the bolt, which is why I'd like to know more about this flexplate method...thanks!)
  12. #12 Re: Harmonic Balancer Bolt Removal
    pop off inspection cover, two 10 mm head bolts, place vice grips on there very tight, enjoy.
  13. #13 Re: Harmonic Balancer Bolt Removal
    Marysville WA
    Like a puller?
  14. #14 Re: Harmonic Balancer Bolt Removal
    Sep 2012
    Savannah GA
    Thanks Matt! I got it, that's an awesome tip, makes life so much easier! (to clarify the inspection cover is a plastic over just rearward of the starter).
  1. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  2. Harmonic Balancer-no Stock??
    By diamondz101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2011, 08:18 PM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
