Thread: Going WOT but boost is NOT.
Results 1 to 20 of 31
  1. #1 Re: Going WOT but boost is NOT.
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Thanks. But I am not really sure this will fix my problem. Seems a little to easy lol.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  2. #2 Re: Going WOT but boost is NOT.
    Quote Originally Posted by fri3dchick3n View Post
    if your belt is torn up, its old, and they tend to stretch/wear the V groves off, then it slips. if all your pulleys seem ok the new belt should stop the squeal and fix the boost.
    some part stores have a gauge you can put in the groves to see the wear.
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. no boost!!
    By jaygtp98 in forum General Tech Discussion
    Last Post: 04-15-2010, 01:12 PM
