Thread: Wondering about gears and powerband...quick question
Results 1 to 12 of 12
  1. #1 Wondering about gears and powerband...quick question
    Jul 2008
    STL
    Just wondering what mph 2000-2002 generation GTP's switch gears in:
    1st gear mph-mph
    2nd gear mph-mph and what rpm you would be in WOT from 1st
    3rd gear mph-mph and what rpm you would be in WOT from 2nd
    4th gear mph-mph and what rpm you would be in WOT from 3rd
    Also what is the sweet powerand in RPM's for GTP's?
    thanks
  2. #2 Re: Wondering about gears and powerband...quick question
    i have 3.29s (it's a GT) and my car shifts around 44, 82, etc. i havent gone fast enough to shift into 4th at WOT. it'd be way over 100.
  3. #3 Re: Wondering about gears and powerband...quick question
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by 02CL-TypeS View Post
    1st gear mph-mph
    thanks
    most depends on your mod level, cam, and any tuning that changes those parameters.
    stock 02 settings from the performance shift tables are as follows
    1>2 WOT 5350 RPM and 42 MPH
    2>3 WOT 5275 RPM and 80 MPH
    3>4 WOT 4400 RPM and 124 MPH
    iirc the powerband is strongest between 3500 and 4500. Look at the cam list sticky. There is a chart with a desktop dyno showing theoretical powerbands for stock and a couple of aftermarket cams.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Wondering about gears and powerband...quick question
    Donating Users blowfishRus6's Avatar
    g.a.
    me being pretty much stock i get full boost around 4500 and up.
    with 3.29 gears. most have 2.93
    1st 45
    2nd 80
    3rd 125
    the rpms drop to about 4k on each shift. i have a video in the lounge of 0-100. you can see what it drops to each gear.
    being about stock with an intake i pull my hardest after 4500 or atleast thats how it feels
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: Wondering about gears and powerband...quick question
    Barksdale AFB, LA
    Peak power on most 3800s that I've seen (in stock form) is around 5200RPM and peak torque in the 4k RPM range.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Wondering about gears and powerband...quick question
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    wtf my cars performance dosent change after 4500 rpm. It just gets real loud and doesnt move any faster. My peak performance is at about 15 mph in first gear. If u hit it right, it will pull very nice.
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  7. #7 Re: Wondering about gears and powerband...quick question
    g.a.
    Quote Originally Posted by Freebeer187 View Post
    i get full boost after 4500 rpm and it feels like it starts to pull harder, i dont really notice it in first but i notice it more in second and a lot more in third.
    that graph that you posted up in the ported manifold thread was showing max torque at about 4300 and hp was still gaining at 5500.
    its slow.
  8. #8 Re: Wondering about gears and powerband...quick question
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    yeah my stock GP goes from
    1>2 @ 50mph
    2>3 @ 85mph
    dunno about forth gear, not sure, maybe 120-125mph
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  9. #9 Re: Wondering about gears and powerband...quick question
    1st Gear is until around 45 or so...shift point set @ 6300 for both...
    2nd Gear goes until about 95 ish
    3rd Gear...ummm...I got it to shift into Overdrive but idk how fast I was going...I am guessing about a buck fitee?
    Edited for a thought...Get a cam...powerband is EVERYWHERE!!! Especially burning the tires AFTER it shifts into 2nd...
  10. #10 Re: Wondering about gears and powerband...quick question
    g.a.
    i also have a gen V blower. dont know if that makes a difference..
    its slow.
  11. #11 Re: Wondering about gears and powerband...quick question
    I live here. UR LOSN's Avatar
    Rockford, IL
    In my GTP I had:
    1-2 shift : 46mph
    2-3 shift: 98mph
    3-4 shift 146mph
  12. #12 Re: Wondering about gears and powerband...quick question
    Aug 2008
    Fayetteville, NC
    wow lol long 2nd gear
  1. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
  2. wondering....
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-11-2008, 01:41 PM
  3. 3.8L S/C Recal. Quick question.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2008, 12:56 PM
  4. just wondering
    By redgt in forum Visual/Body Modifications
    Last Post: 02-28-2008, 04:43 PM
  5. Just wondering
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 12-23-2007, 12:31 AM
