Thread: Now supercharged
Results 1 to 10 of 10
  1. #1 Now supercharged
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    I just got done making my 2005 base into a supercharged gp. The boost gauge is showing 3. Seems low? i have the stock pulley on it, no KR and codes for the o2 and map sensor voltage. Any ideas, I also have the breather on the valve cover...
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: Now supercharged
    TDCRacing
    Guest
    Do you have the vacume line for the BBV connected? When unplugged it limits it to 3psi. Also i think i read somewhere that it may have something to do with the pcm...I made a point to remember but now i forgot. But maybe that had to do with s/c'ing a older model gp. I'll look now to see if i cant find it
  3. #3 Re: Now supercharged
    Apr 2008
    ny
    I figured it out. I just disconnected the vacume lines to the bbv and its now working fine. Just have to try to figure out how to deal with the codes...P0030, 0053, 0131, 0243, 1106, and 0229
  4. #4 Re: Now supercharged
    TDCRacing
    Guest
    glad you got it figured out
  5. #5 Re: Now supercharged
    Apr 2008
    ny
    me too!!!
  6. #6 Re: Now supercharged
    a top swapped car either needs a l67 pcm to be able to run the bbv, or to just run it vacuum controlled my disconnecting the lower vacuum line and leaving it open. so, good thing youve figured that out.
    now fix the rest of your mess.
  7. #7 Re: Now supercharged
    Apr 2008
    ny
    yes it runs much better now. i am going to replace the o2 sensor next. We will see what happens.
  8. #8 Re: Now supercharged
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I demand a picture!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  9. #9 Re: Now supercharged
    Jan 1970
    Maquoketa, Iowa
    po243 is the code for the BBV when I disconnected mine, ran at 3-5 psi boost like he said...
  10. #10 Re: Now supercharged
    Apr 2008
    ny
    Here she is........
  1. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  2. worlds smallest supercharged v8
    Last Post: 07-26-2008, 09:40 AM
  3. me vs. supercharged cav
    By boosting98 in forum Track Sessions and Kills
    Last Post: 05-03-2008, 12:32 AM
  4. Supercharged issues?
    By lt1transam in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2008, 02:56 PM
  5. Supercharged G8 vid from Europe
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 04-07-2008, 04:41 PM
