Thread: intermittent engine problem?
Results 1 to 6 of 6
  1. #1 intermittent engine problem?
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hey guys recently I have been having this odd problem with the gtp. The thing is that when I accelerate at a steady pace (not wot) the rpms is steady the sort of loses power or falls a bit and then goes back to where it was at. At first I thought this happened because I was running out of gas but it still did it after a refill. I have no clue what this could be anybody have any idea? Also no it is not at shift points.
    car has 110k kms on it always maintained well.
  2. #2 Re: intermittent engine problem?
    St. Louis
    Is the CEL on? Have you cleaned the MAF? What plugs are you running in it? Always using 91+ octane gas? What year is your car?
  3. #3 Re: intermittent engine problem?
    Doing any scanning? There can be some KR at points in our tunes. You might be hitting a bit.
  4. #4 Re: intermittent engine problem?
    May 2011
    Ontario
    My car is an 04. the CEL actually is on but has been for about a year. It was brought into the dealer last year i think and they said the CEL was just due to a sensor issue and the wanted 400 bucks just to disable it. I always run 91 actually but not sure if the previous owner did. As far as plugs go im not sure whats in there now all I know is that they have only been changed once maybe. The issue hasnt happened this past week but it definitely gave me a scare when it happened.
  5. #5 Re: intermittent engine problem?
    Please have the CEL checked. It may be the issue.
  6. #6 Re: intermittent engine problem?
    Apr 2009
    Fort Worth TX
    I would like to know what sensor they would "disable" and why it's OK to do so. Why not just fix it?
    A bad knock sensor(s) may retard the timing when it doesn't have to. On the other hand it may not retard the timing when the motor is actually knocking, very bad.
    Do what these guys say and get the car scanned before the motor fails. Better to spend a little cash now rather than a lot more later.
  1. intermittent engine problem?
    By des19 in forum Engine
    Last Post: 03-11-2012, 01:47 AM
  2. intermittent ps problem
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2011, 02:45 PM
  3. Intermittent Starting Problem...
    By Claude in forum General Tech Discussion
    Last Post: 03-17-2011, 08:33 PM
  4. 94 GP 3.1 Auto - intermittent starting problem
    By Dergibog in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-04-2011, 07:41 PM
  5. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
