Thread: Reuse oil pan gasket with RTV?
Results 1 to 5 of 5
  1. #1 Reuse oil pan gasket with RTV?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I'm trying to save a bit of money on my build. Can I just reuse the oil pan gasket and put some RTV on both sides of it?
  2. #2 Re: Reuse oil pan gasket with RTV?
  3. #3
    Okay. Just making sure. Thanks Bio.
  4. #4 Re: Reuse oil pan gasket with RTV?
    Yes. Afterall..the upraised area on a new gasket isn't worth much. Barely seals if you are lucky. If I was using the craplastic gasket, I'd RTV the crap out of it.
    Or get something like an engine sealant. That's what GM uses to seal their aluminum pans to the engine if they didn't put a rubber inlaid gasket in them.
  5. #5 Re: Reuse oil pan gasket with RTV?
    Antioch, IL
    Thats what I did. 12k miles or 1 yr and its still golden. My 06 mazda 3 i had didnt use a gasket it was just rtv.
    2009 Challenger SRT8
    Expert at being gay.
  1. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  2. Reuse L36 upper plenum gasket?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2012, 08:19 PM
  3. Oil Pan Gasket
    By jacobmh27 in forum General Tech Discussion
    Last Post: 12-01-2011, 09:38 AM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  5. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
