Thread: Bad Knock
Results 1 to 16 of 16
  1. #1 Bad Knock
    Donating Users Joe's Avatar
    Waterloo, IA
    I have a 2000 GTP all stock but I have; U-Bend Delete, Gutted Air Box, Stock Tune with fan changes for 180* Stat, Autolite 605 gapped at .055".
    Scanned it the other day and I am getting a LOT of knock. This is from a scan today(34 degrees Fahrenheit during scan) about a 40min drive. Histogram showing highest values.
    What would cause this much knock? Before I would only get up to 2 or 4 and that was rarely. Car seems to drive fine, no misfires or anything.
    Thanks,
    Joe
    2000 Grand Prix GTP
    e: JTuckGTP@gmail.com
  2. #2 Re: Bad Knock
    scans and bin plz.
  3. #3 Re: Bad Knock
    Out West
    Probably the cold weather.
    Whine with your Cheese?
  4. #4 Re: Bad Knock
    Joe,
    How's the condition of the motor/trans mounts?
    If they are shot...and the motor moves enough...downpipe can come in contact with the sway bar under heavy acceleration...giving the knock sensors false readings.
    As well, are you using 91+ octane?
  5. #5 Re: Bad Knock
    Waterloo, IA
    I was thinking mounts, ordered some online but they looked fine when I actually jacked the car up and looked. Might have to get a friend and see if the engine moves when it is put in gear. And I only run 91/92/93 octane. Also cold weather should HELP knock if I'm not mistaken?
    2000 Grand Prix GTP
  6. #6 Re: Bad Knock
    Quincy, Mass
    Its your STOCK tune. the stock tune will produce knock. my girls base model 06 sees up to 8* at times. Colder weather, denser air, will cause an increase in knock too, many who run a 3.4 in the summer will switch to a 3.6 in the winter to get rid of the knock.
    you'll be able to tune that knock out since you appear to have a tuner.
    No more GP 04 Impala SS Indy:
  7. #7 Re: Bad Knock
    Waterloo, IA
    Scan:
    HPL
    CVS
    HPT File
    2000 Grand Prix GTP
  8. #8 Re: Bad Knock
    You still have the stock front manifold, its pretty restrictive
  9. #9 Re: Bad Knock
    Quincy, Mass
    and we are still on winter blend gas right now so that can cause some knock.
  10. #10 Re: Bad Knock
    Waterloo, IA
    Good point, I had the power log till it rusted out. Forgot about that, also had a 3" DP till that rusted out too, now just have the U-Bend delete. Thanks for all the help, I will be trying to tune it out in the next few weeks. Just shocked me when I saw how much knock it had, figured something was wrong.
    Thanks again,
    Joe
    2000 Grand Prix GTP
  11. #11 Re: Bad Knock
    And actually, winter causes MORE knock...colder, denser air...means moar booosteses.
    Summer has less knock...crappier air as well, more humid...less boost.
  12. #12 Re: Bad Knock
    Waterloo, IA
    Learn something every day. Just assumed the colder air would keep the temps down causing less knock.
    2000 Grand Prix GTP
  13. #13 Re: Bad Knock
    Out West
    Sorely mistaken, guy.
  14. #14 Re: Bad Knock
    Pennsylvania
    Clean your MAF?
    How many miles are on your spark plugs? Those copper cores don't last forever, you know.
  15. #15 Re: Bad Knock
    Waterloo, IA
    Should probably clean the MAF, been a while. And spark plugs were changed 2 weeks ago, usually change them twice a year.
    2000 Grand Prix GTP
  16. #16 Re: Bad Knock
    Waterloo, IA
    Joe,
    Just an update, it was in fact the trans mount. Now the most knock I see is 3, should be able to tune that out next week.
    Thanks a lot,
    Joe
    2000 Grand Prix GTP
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. knock
    By 04BlackComp_G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 12:27 AM
  3. 00 GT rod knock
    By Sameyeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 05:57 PM
  4. help with the knock please
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:29 PM
  5. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
