Thread: MSD blaster coil pack question
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 MSD blaster coil pack question
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    I'm looking to order a set of msd coil packs. On 3800 performance they have the set for $150. From jegs I can get the set for $130 IF they are the same. 3800 perf. doesn't list the part number. Jegs lists the part number. Does anyone know the part number that fits the gp or know if these are the same coils? Thanks in advance.
    MSD Blaster Ignition Coil Packs: 3800 Performance
    MSD Ignition 8224 MSD Blaster Replacement Coils
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  2. #2 Re: MSD blaster coil pack question
    Oct 2008
    mascoutah, Il
    I'm sure others will chime in but why are you buying the msd packs?
    Factory packs are more than sufficient, and If I have read the research correct, the msd packs have less power and are not as durable as factory.
    2002 GTP
    custom HOK paint
  3. #3 Re: MSD blaster coil pack question
  4. #4 Re: MSD blaster coil pack question
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Why do you say waste of money?
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  5. #5 Re: MSD blaster coil pack question
    stock coil packs work at any power level you can throw at them and the MSD coils are rated for the L36 coils.
  6. #6 Re: MSD blaster coil pack question
    Oct 2008
    mascoutah, Il
    use the money elsewhere
    2002 GTP
    custom HOK paint
  7. #7 Re: MSD blaster coil pack question
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    my car got a better throttle response ever since i put mine on with the wires.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  8. #8 Re: MSD blaster coil pack question
    With wires...
  9. #9 Re: MSD blaster coil pack question
    GEORGIA
    well yea, i wouldnt use stock 7mm wires with them. its doin alot better than when it had the stock coils and wires, thats what they r 4, bigger more constant spark. also i got them and the wires 4 $60 shipped.
  10. #10 Re: MSD blaster coil pack question
    Nov 2009
    Portsmouth, OH
    My reason for getting new coils is because my car has a little bit of a rough idle. I've put 2500 miles on the car and its thrown a random misfire code twice. It has new plugs and wires, so I was thinking it wouldn't hurt to replace them. I'm pretty sure they are original and the car has 127k miles. I'm not expecting any hp gains or anything. I was just looking to get some new ones to smooth out my idle. So, I'm better to just replace them with OEM packs?
  11. #11 Re: MSD blaster coil pack question
    Wooster, Ohio
    I have no experience with the msd coils on our cars, but it sounds like your best bet would be spend your money on plugs/wires/fuel filter, and see what happens. Upgrade to a performance wire anyway so that if you do, later wanna try the MSD packs your already good to throw em on.
  12. #12 Re: MSD blaster coil pack question
    Quote Originally Posted by a98gtp4u View Post
    well in that case then your stock coils were on their way out. there is no way MSD coils are better in any way.
  13. #13 Re: MSD blaster coil pack question
    ^^Agreed.
    They are just there for eye candy or if you have the money to waste on them when your stockers are taking a dump. Your wires were probably on their way out too.
  14. #14 Re: MSD blaster coil pack question
    GEORGIA
    well got it all $60 shipped, not complaining. they work just fine. btw, i work at autozone and the stock l36 and l67 coils r the same.
  15. #15 Re: MSD blaster coil pack question
    SE Level Member beast3300's Avatar
    No their not. The aftermarket companies list one coil but GM does not. L67 coils are different than L36/any other GM cars.
    L67 coil= D576
    every other GM= D555
    (delco part numbers.)
    Like everybody said, stock are the best.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  16. #16 Re: MSD blaster coil pack question
    Wooster, Ohio
    what is the difference between the 2 coils?
  17. #17 Re: MSD blaster coil pack question
    Nothing...although some seem to think there is.
  18. #18 Re: MSD blaster coil pack question
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Waist of money.
    When i had my prix fully modded i lost power with them. Dyno proven
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  19. #19 Re: MSD blaster coil pack question
    Nov 2009
    Portsmouth, OH
    Got it! I'm going to get some new OEMs tomorrow. I gotta get this rough idle fixed. Makes it feel like a POS. Thanks for the help guys!
  20. #20 Re: MSD blaster coil pack question
    Quote Originally Posted by JoelW98GTP View Post
    Why not buy some perfectly good OEM used one
    PM about them if you haven't bought NEW ones yet...
  1. Fuel Pump? Coil Pack?
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2009, 04:59 PM
  2. lighter coil pack bracket?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 08:29 PM
