OK so I got the car home. But I had problems along the way and need advice of where to start to repair the issue. The car would run fine for about 20-30 miles and then the service traction control and service ABS system would appear on the DIC followed shortly after with reduced engine power and the car would die. I would pull over and clear the codes with my scanner and it would start back up and run fine again for another 20-30 miles. The codes that were given were the same codes that I mentioned before (P0068, andP0101). Another thing that I don’t know if it is related or not but the boost gauge was not going up. It felt like it was getting some boost but not as much as before the engine swap. I tried the carb and choke cleaner trick but it didn’t affect anything when I sprayed everywhere around the vacuum lines and around the base of the supercharger. Bill I know you can help me with this one. Thanks in advance everyone.
