The lifters once all the way up were kinda stuck there too. I'm gonna check tomorrow to see if the lifters can fall out once the cam is out and if I use a magnet to pull the lifters up if the lifters will stay by themselves. If the don't fall out and stay up then its entirely possible to do this job right side up and only use one magnet..
Just curious with my car being a daily driver and keeping the stock chain would you guys recommend keeping the balance shaft in? If so is there any wear parts I need to check for on the balance shaft??
Thanks for any input
Sent from my DROIDX using Tapatalk
