I'm likely going to try it on the next cam swap that I do, in two weeks. Please do let us know.
Depends on the springs and your expected rpm. If you bump it 100rpm that makes the cam/chain wear the dampener less. With 105's, L76's or LS6's, I'd likely use a stock replacement chain. More spring..bump up to a double.
