Thread: Shift
Results 1 to 11 of 11
  1. #1 Shift
    Illinois
    Im not sure if im in the right section but I will try. I have a 99 gtp supercharged , automatic(just got it) when it shifts from 1st to 2nd its shifts at about 19mph but when it shifts from 2nd to 3rd it doesnt shift till between 46 to 52 mph. is this right or do i have transmission problems. Any help would be great.
  2. #2 Re: Shift
    new britain, ct
    are you flooring it or driving normally? and by normally...i mean not flooring it.
    07 Black GXP.
  3. #3 Re: Shift
    Illinois
    normal driving.
  4. #4 Re: Shift
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Isn't 45 the shift point?
    The evil LG8 still refuses to die.
  5. #5 Re: Shift
    The Boss Iceman6669's Avatar
    Jun 2011
    under "heavy" acceleration first gear will shift around 45ish, second gear shifts around 85ish and 3rd gear won't shift into OD on a stock car....
    Under light accel, it is hard to say. Depends on throttle position and incline.
    2011 F-150 Yote powered
  6. #6 Re: Shift
    Illinois
    Thanks guys, sounds like it is shifting normal. Just curious since its my first S/C and fist Grand Prix.
  7. #7 Re: Shift
    normal throttle the car will shift from 1st to 2nd around 10-20 mph and from 2nd to 3rd a little after 32-35 give out take some. Then hit 4th gear around 45+
  8. #8 Re: Shift
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    More than 25 % tps, I feel that they shift late anyway. Crazy to have 40% tps and 4800 shifts.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  9. #9 Re: Shift
    sound like you lost 3 rd gear, had the same problem myself. 3 rd should lock up around 30 to 34 mph. so if its not shifting till 43 or so, your shifting into over drive aka 4th gear.
    when you are going over 50 mph, drop the shiftier into 3 rd gear, if the rpms don't jump up, you lost 3 rd.
  10. #10 Re: Shift
    Illinois
    scottydoggs
    I just took it for a drive I hit about 53mph put it down in to 3rd and it jumps from around 1500 rpm to 2500
    rpm.
  11. #11 Re: Shift
    that sounds ok then.
  1. How do you add tap shift to an 06 gt
    By merciero in forum General Tech Discussion
    Last Post: 04-10-2012, 10:28 PM
  2. Shift kit for 97 gt?
    By 97whitegt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2010, 11:15 PM
  3. Need help with a shift kit
    By MrClean in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 11:52 AM
  4. shift kit
    By offroadfury6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 10:11 AM
