He's not saying a L26 is more reliable than a L36, just that the factory build of the bottom end is much more reliable than any rebuild. Just can't do it as good as it was the first time.
If I had the choice, I'd get a 05+ L26 (04 L26 uses the same rods as L36) long block and replace the TB/fuel rails with L36 variety so it's compatible with your car. Then do what you want with it.
Reptile is right that Series III has larger valves on the exhaust side (if memory serves).
