Thread: replacing supercharger questions
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: replacing supercarger questions
    No one agrees on P&P.
    Polish/smooth inlet and call it a day.
  2. #22 Re: replacing supercarger questions
    Jan 2012
    Abilene, KS
    i figured thats what i was gonna do as far as p&p i just didnt know if i should replace any bearings in the snout or if the needle bearings should be replaced
    How worn are they?
  4. #24 Re: replacing supercarger questions
    Jan 2012
    Abilene, KS
    im not sure...how could i tell?
  5. #25 Re: replacing supercarger questions
    typically when the engine is idling you'd hear bearing noise coming from the blower.
    if you remove the blower belt and its much quieter, it's the blower.
  6. #26 Re: replacing supercarger questions
    Jan 2012
    Abilene, KS
    Well it wasn't on the car it came with it when i bought it....the guy I bought it from said he picked it up for a hundred dollars because it was cheap....he said it came off a bonnie with 50 some thousand miles on it....but that's a story from a story so I'm not sure
  7. #27 Re: replacing supercarger questions
    Jan 2012
    Abilene, KS
    Is there any other way I could tell?
    Not that I'm aware of.
  9. #29 Re: replacing supercharger questions
    Jan 2012
    Abilene, KS
    Would I be able to hear it just by spinning it by hand?
  10. #30 Re: replacing supercharger questions
    Jan 2012
    Abilene, KS
    How much work would it be to replace the needle bearings and the bearings in the snout?
  11. #31 Re: replacing supercharger questions
    There are write ups somewhere.
    You need a press or sockets to tap them in.
    Are you sure your blower is making excess noise?
  12. #32 Re: replacing supercharger questions
    Jan 2012
    Abilene, KS
    I think It's fine I was just wondering if i should bother replacing them since I'm gonna be doin a couple other things on it or should i just leave it
  13. #33 Re: replacing supercharger questions
    If you cant do it yourself it can get pretty pricey.
    You can typically pick up a nice used blower for $100 or less.
  14. #34 Re: replacing supercharger questions
    Postville, IA
    So I got a 2000 bonneville Ssei n the lady said when the belt broke n pulley came off the super charger the supercharger hasn't worked since she was told the bearings in the super charger are probably bad would it be cheaper to have just the bearings changed or should I just change the whole thing? It just kinda chugs instead of the supercharger kicking in and you can hear a kinda clicking noise coming from the supercharger
  15. #35 Re: replacing supercharger questions
    used blower would cost less.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. Should I try replacing my PCM?
    By 50Coupe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 04:17 PM
  3. Replacing steering rack, Questions.
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 12:48 PM
  4. replacing my a4 - gtp or gxp?
    By burninator in forum Off Topic Discussion
    Last Post: 06-30-2010, 06:50 AM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
