Thread: Boost Control Solenoid/EVAP?
Results 1 to 18 of 18
  1. #1 Boost Control Solenoid/EVAP?
    GT Level Member pski920's Avatar
    Oct 2008
    Endicott NY
    After starting my car, it stalls after about 5 sec. It just cuts out, and if i rev it as it stalls out, i can save it for a sec. and then it stalls again. I used a high quality scanner on my car and it flashes a P1646 code (Boost Control Sensor). Is this a typical result of a bad BCS? Or is it flashing this code due to another problem? Has anyone run into this problem before? I've looked online for a sensor (or switch) to see what it looks like because i am not sure where it is located. I think it is in front of the SC and behind the front valve cover and has a harness going into the left of it and a vaccum line running out of the right. Any help would be appreciated greatly!
  2. #2 Re: Boost Contorl Sensor
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Um, there is no Boost Control Sensor on these cars.
    P1646 is for the EVAP Vent Solenoid control circuit, which is the one back by the gas tank. I wouldn't think that would be causing your problem.
    What year is your car? Could be the fuel pump resistor.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Boost Contorl Sensor
    Oct 2008
    Endicott NY
    the scanner read Boost Solenoid/5v ref. C/ EVAP Vent Circuit. i thought it was sensor, but i meant solenoid. it wouldn't cause it to stall suddenly after 5 sec? what could it be? i tried pulling the MAF sensor to see if it worked, and it still stalled. and i cleaned the idle control valve too. my car is a 1998.
  4. #4 Re: Boost Control Solenoid/EVAP?
    Oct 2008
    Endicott NY
    Thanks Scimmia, I think that's what it may be after finding out some info from a friend. He told me exactly what you told me, but when you responded I couldn't find anything on where this resistor was. Do you know exactly, and possibly a part number?
  5. #5 Re: Boost Control Solenoid/EVAP?
    QCA, IA
    Try this, it should bypass the resistor all together and tell you for sure if it's the problem.
    http://www.scacgp.com/mods/fuel_fix/relays.jpg
  6. #6 Re: Boost Control Solenoid/EVAP?
    Oct 2008
    Endicott NY
    Thanks, I'll try it tmw. since the weather here in Upstate NY BITES! I'll let you know how i make out, and i got a resistor for 35 dollars from my cousin who works for a gm dealership. is that a good price?
  7. #7 Re: Boost Control Solenoid/EVAP?
    QCA, IA
    Sounds about right, but I've never had to deal with it directly; the L36 never used the resistor, and GM quit using them in the L67 after 2000 anyway.
  8. #8 Re: Boost Control Solenoid/EVAP?
    Oct 2008
    Endicott NY
    ahh, they actually realized thier problem and dealt with it. amazing. i appreciate your help and i will get back to you and let you know how it turns out tmw.
  9. #9 Re: Boost Control Solenoid/EVAP?
    I gave you that pic in another thread too
  10. #10 Re: Boost Control Solenoid/EVAP?
    Oct 2008
    Endicott NY
    NICE! Thanks...again.
  11. #11 Re: Boost Control Solenoid/EVAP?
    Jul 2008
    Germantown, Maryland
    my resistor went bad... i bent tab 85 and the problem disappeared.... great free mod...
  12. #12 Re: Boost Control Solenoid/EVAP?
    Oct 2008
    Endicott NY
    Thanks guys, I replaced the resistor and it worked. Also, when I got the part, it came as the relocation kit as well. So I mounted it to the firewall (since it will prob. happen again). haha...thanks again!
  13. #13 Re: Boost Control Solenoid/EVAP?
    Jul 2008
    bend pin 85 and it will never happen again
  14. #14 Re: Boost Control Solenoid/EVAP?
    tennessee
    sorry guys but if u bend pin 85 the car dies isnt it like 87b tht needs to b bent??? and we are talkin about relay 14 in the engine compartment fuse box correct
  15. #15 Re: Boost Control Solenoid/EVAP?
    Yoga city
    all tha does is make your fuel pump work harder in high mode, the resistor controls the pump while the car is running.
  16. #16 Re: Boost Control Solenoid/EVAP?
    tennessee
    ok youve lost me my car doesnt have a resistor... it has a 5 pin relay which has 2 seperate numberings on it... so the diagram on the relay referrs to a pin labeled 85 and i flip it over and look at the referred pin and said pin is labeled 87 wtf???
  17. #17 Re: Boost Control Solenoid/EVAP?
    A 97-03 GTP has a resistor. It's located down behind the window washer container in a pain in the neck place. If you have a speed control relay in your fusebox... bend the pin. Searching on pump resistor will net you a picture or two. I would link you..but this pos I'm using isn't all that good.
  18. #18 Re: Boost Control Solenoid/EVAP?
    tennessee
    ok... so i tried the pin 85 to no avail... fp doesnt even prime ill look for the resistor later as the car still runs... and now my ltfts are at zero all the time... i despise electronics for the time being
  1. Boost Control?
    By RicerKiller in forum PCM Tuning
    Last Post: 04-29-2009, 08:55 AM
  2. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
  3. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  4. Boost by pass
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:35 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
