Thread: Temp sensor problem
Results 1 to 4 of 4
  1. #1 Temp sensor problem
    Mar 2012
    Florida
    I just completed the LIM gasket replacement along with everything else including replacing the temp sensor on the intake. After all complete the temp gauge stays pegged even when the car is cold? What could this be? Bad sensor? Wiring? Any way to test before removing? Thanks,
  2. #2 Re: Temp sensor problem
    Check connections. On most years, there is a second connection by the #3 fuel injector connection.
  3. #3 Re: Temp sensor problem
    Mar 2012
    Florida
    I have that plugged in as well. If I unplug the temp sensor the gauge drops back down.
  4. #4 Re: Temp sensor problem
    St. Louis
    Are the connection points nice and clean? Could be a bad ground. Either that or the new sensor could bad.
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. Temp sensor?
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2011, 06:53 AM
  3. Temp. Sensor?
    By Peirce1970 in forum General Tech Discussion
    Last Post: 01-27-2011, 08:01 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. Car won't stay running - Coolant Temp and TPS sensor problem?
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 10:37 PM
