Give your fuses a check. A 15a ignition fuse comes to mind. Other than that, maybe you just got a bad MAF? Try unplugging the MAF and then starting the car and see if it eventually smooths out. If it does, then turn the car off, plug the MAF back in and restart. If it runs like junk again then you probably have a bad MAF, which is possible for even a "new' one.
