Thread: A Few Swap Questions
Results 1 to 9 of 9
Threaded View
  1. #1 A Few Swap Questions
    mke
    So some of you may know me, some may not. I had a 96 Lumina i had done an l67 swap in, and am now doing just about the same in my 97 GT. I was going to go the turbo route but with school and working full time i decided id go the "more reliable" and money saving route. Just some questions/unclear stuff to me as far as doing the swap in a gp before i begin to gather parts...
    1) I am getting a low milage topswapped l36 from a buddy of mine. I am going to get a 98+ harness and pcm, therefore getting rid of the dreaded 97 pcm/wiring. Should i get a 98+ GTP or GT pcm since the motor is topswapped? What changes do i need to make to the harness if i were to get a gtp harness? Any changes at the firewall wiring wise? I know in my lumina i had to change some wiring at the c100 connector..
    2) I will be getting a built trans. Currently i have the 4t60 vac trans, so that is another reason i am upgrading my wiring harness, to control the trans. I am either going to do a beefed up 4t65 to keep 3.29's or a 4t65hd. If i do a 4t65hd Do i just simply get 98+ GTP axles? Also, if the trans will be a 4t65hd will it bolt straight to the l36 block/flex plate?
    3) Since i will be upgrading the harness and pcm to a 98+, will my gauge cluster/dic still function properly? The only thing ive read up so far is no abs (i can live without it), the temp gauge along with the fuel level gauge will not read correct with a different pcm.
    4) Trans lines. I know the 97's had different trans fittings in them. What route must i go with these sense ill be swapping the trans?
    I hope i can get some answers and insight, and thanks in advance for the help!
  1. L36 Swap Questions
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2013, 07:18 AM
  2. a few top swap questions
    By The Wolf in forum General Tech Discussion
    Last Post: 09-07-2011, 11:52 PM
  3. Gen V Swap Questions
    By jdbaringer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:44 PM
  4. Top Swap questions...
    By codyAK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 08:00 AM
  5. Top swap questions
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 02:15 PM
