Thread: Best Spark plugs to use?? IC question
Results 1 to 8 of 8
  1. #1 Best Spark plugs to use?? IC question
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    Had al104s but got a full size IC done and 3.0 pulley was wondering if switching plugs which would be best to use??
    Also when filling IC should I use all water or coolant? Just curious cause I was told to use both but making sure
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: Best Spark plugs to use?? IC question
    Try the same plugs.
    See how they burn.
    I've added boost, then an intercooler and more boost, and I find AL104's and TR6's still too cold.
    Coolant in the system, otherwise corrosion will take place.
    You can run as little as thirty percent coolant and still maintain that.
    If you're using Dexcool in the engine cooling system I'd suggest a premium coolant like Prestone in the intercooler system to make it easier to identify which cooling system is leaking.
  3. #3 Re: Best Spark plugs to use?? IC question
    Mercer, Pa
    Your in Texas so freezing isn't as big a problem but I would run some coolant for corrosion protection.
  4. #4 Re: Best Spark plugs to use?? IC question
    Galveston, Texas
    So al103 aren't a good idea or would something else be better
  5. #5 Re: Best Spark plugs to use?? IC question
    try them
  6. #6 Re: Best Spark plugs to use?? IC question
    Galveston, Texas
    At what gap should I use them at
  7. #7 Re: Best Spark plugs to use?? IC question
  8. #8 Re: Best Spark plugs to use?? IC question
    Pennsylvania
    Always use the hottest plugs you can get away with.
  1. Spark Plugs
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2011, 02:15 PM
  2. question about spark plugs
    By DaytonaGTP in forum General Tech Discussion
    Last Post: 04-12-2010, 02:00 AM
  3. What Spark Plugs do you run?
    By RiceBurnt6 in forum Off Topic Discussion
    Last Post: 02-05-2010, 04:47 PM
  4. Question on spark plugs
    By Durk Diggler in forum General Tech Discussion
    Last Post: 09-09-2009, 10:18 AM
  5. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
