Thread: Engine rebuild kit
Results 1 to 5 of 5
  1. #1 Engine rebuild kit
    SE Level Member dipset1413's Avatar
    Jun 2010
    Chicago
    Anyone know where i can get a engine rebuild kit for a 04 supercharged engine i got a lil lifter noise coming from it and today i threw a p0303 cylinder 3 misfire code so imma just redue it 145k on the dash
    3.8 supercharged hud screen four monitors crazy system yea its over kill so
  2. #2 Re: Engine rebuild kit
    St. Louis
    Woah, you're gonna rebuild it just because you got a little bit of lifter noise and a cyl 3 misfire? Talk about jumping the gun. And 145K isn't high for these motors so I highly doubt a "rebuild" is worth it. Have you even tried troubleshooting these issues? Bad plug wire? Bad plug? Bad Coil?
    It is expensive to rebuild these motors correctly and have them last. You have to have the block align bored and the entire bottom end checked out or it will most likely grenade on you shortly after reassembly. A machine shop assembling your entire bottom end would be best.
    Beyond that, I would go w/ a low mileage longblock and just swap over your stuff and call it done. Way cheaper and you know the bottom end is good.
    And before I forget, are you COMPLETELY stock right now, or did you drop a pulley size or something? Are you running premium gas in it?
  3. #3 Re: Engine rebuild kit
    You don't.
    Unless you want to spend one to two thousand.
  4. #4 Re: Engine rebuild kit
    GT Level Member nicks98gtp's Avatar
    michigan
    northern auto parts is who i got mine through. i believe it was $1500 shipped with a new cam which is the most complete kit they sell
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  5. #5 Re: Engine rebuild kit
    I've seen a lot of these motors in pieces. I've seen a few with ~200K on them still have cross hatches in the cylinders. The rings don't wear much, overall ... good motors.
  1. Possible Engine Rebuild?
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2012, 02:48 AM
  2. Engine rebuild
    By SuperchargedFiero in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 05:43 PM
  3. Engine Rebuild
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 07:48 PM
  4. Engine and Trans rebuild??
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 03-08-2010, 11:35 PM
  5. Engine rebuild
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2010, 01:10 PM
