Thread: Top Swap Pulley Options.
Results 21 to 40 of 43
  1. #1 Re: Top Swap Pulley Options.
    Grand Island, Nebraska
    I believe you, top swaps arent cheap. I think they are just getting at the point that the cam is much cheaper to install while you have the engine tore apart already. I had my heads and valves redone for <$40, and it still cost me a grand and a half, with cheap headers. Personally my next step is E85, I've heard good things. All I need is a wideband (which i need anyway) and some injectors. Oh and a pulley youll be happy with the top swap for sure, but not quite as happy as you could be lol.
  2. #2 Re: Top Swap Pulley Options.
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    go with speed daddy, they are cheaper and ive heard they are better than zzp's togs plus you get a down pipe instead of spending 100 more
  3. #3 Re: Top Swap Pulley Options.
    Omaha, NE
    Quote Originally Posted by Mjcanton View Post
    wtf do you people not understand about a budget? Seriously? If you have nothing to contribute about what pulley I'll be able to run then don't comment. With your logic I might as well build a tranny, Get a IC, Gen 5, heads and go balls to the wall.
    When did a tranny, IC and heads become balls to the wall? LMFAO.
    I'm about to put a 2.8 on my topswap, hope that helps.
  4. #4 Re: Top Swap Pulley Options.
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    I'm just telling you before you learn the hard way your going to kill that tranny even on a plain old stock top swap and if your on a budget don't do it because you will blow your transmission up and if your not doing a cam or anything you should stay with a 3.8 pulley that way your engine doesn't end up like your transmission does
  5. #5 Re: Top Swap Pulley Options.
    And my tranny is doing fine. Just dont do any one wheel wonders or run slicks. The only difference is the differential and gear ratio.
  6. #6 Re: Top Swap Pulley Options.
    Feb 2008
    Quote Originally Posted by JoRoW99 View Post
    Yup, I don't think most people realize the HD tranny isn't that different.. I've talked to tons of people that have been more than fine with the normal Non-hd transmission. Only difference is the differential, one of the axles (pass side?) and gear ratio. Stay away from hard launches and you're good to go normally.
    Plus I don't beat the living piss out of my car like some people do, and I don't go to the track either.. More of a daily driver, just want more power.
  7. #7 Re: Top Swap Pulley Options.
    If youre not wanting advice then dont ask for it...
    Bio was simply trying to tell you that to get anywhere with a top swap would require more mods and not simply the classic "what pulley could I run" question could really apply...
    once you start modding (especially top swapping) its obviously going to impact the entire car... instead of getting mad about information being givin to you, listen, and it may make you change your mind about your initial goals/idea with how youre wanting to modify your vehicle...
    to answer your original question... put on X size pulley, scan, adjust, then repeat as necessary changing X.... thats the only way to know...
  8. #8 Re: Top Swap Pulley Options.
    Feb 2008
    Quote Originally Posted by gtpsleeper View Post
    All I was asking is what pulley is acceptable to run safely with those mods. I said nothing about future modding. I had a very simple question. Kind of similar to GTP guys running headers, intake etc with a 3.4" pulley - common practice that people do when they BEGIN to mod - I wanted to know if I could also drop a pulley size. Obviously things follow in the future (cam, IC, trans, etc.). But that wasn't my question.
    I completely understand why a cam would be ideal to put in now if it was in the budget. I'd love to do a lot of things right now, but things have to be done in steps and I need to stick to my budget. Most people don't go from a stock car to a fully built race car over night. The only reason I am getting ticked off is because this is my build which I have planned out and I was just curious what pulley could/should be ran. I've already gathered plenty of information, so now I'm focusing on the minor details (like pulley size).
    If you care to know my current short term goals -
    1: This summer - Top swap and TOG headers. Get a solid tune. All of my parts have been accounted for and I'm already going to be over budget with the money I spent getting the heads redone and the extra money I put into TOGs vs SD headers.
    2: Depending on how money looks at the end of the summer with my internship, maybe find a set of modified rockers and possibly pulley down or save the cash for the next summer. (I don't do anything mod-wise during the school year as I don't have enough cash coming in).
    3: For all I know I could Cam it a year or two from now, but it won't be until I have extra cash set aside and money to build a transmission. I'd rather bite the bullet then and do gaskets twice then spend all of my money now and be dead broke. I like to have plenty of money set aside to pay for school bills etc. instead of being dead broke and having a faster car.
    I likely will never get to number 3, especially if I do rockers. As of now I'm not really planning on even doing rockers either, just something I've put half a thought into.
    Sorry if I came off as a dick, but It gets really annoying when you ask a specific question and people tell you things that are pretty much irrelevant to the question. I'm much more active on ClubGP and my local forum, so it's not like I haven't been exposed to that stuff before.
  9. #9 Re: Top Swap Pulley Options.
    Out West
    get a cam.
    till then don't even think of touching the stock pulley
    Whine with your Cheese?
    Ohio
    Uhh what about the hardened internals from the factory? Like the input and 4th clutch hub?
  11. #11 Re: Top Swap Pulley Options.
    Quote Originally Posted by 99pgpgt View Post
    I forgot about this comment. That part is only in the 2003+ trannys. And its only for 4th (OD) so it has nothing to do with performance unless youre going WOT at 150mph or something crazy like that. Theres no hardened input shaft, shift kit, or anything different between the regular trannys the HD trannys than what was stated above.
  12. #12 Re: Top Swap Pulley Options.
    Feb 2008
    Yep, that's why I'm not too worried. A few local guys have been more than fine with even more aggressive driving habits than myself. I get on it from time to time, but rarely is it from a dig.
  13. #13 Re: Top Swap Pulley Options.
    Feb 2008
    I don't think I'll be as happy as I could be until I get into a car with 300+hp from factory with a 6 speed manual to be honest lol. I hate the 4 speed in these cars.
    Right now I've spent $200 on a parts engine, $275 on getting the heads completely redone, and $400 on Ceramic coated togs with a SS DP from ZZP. Plus another ~$100 on miscellaneous stuff and cleaning supplies. I still need all of my gaskets and a few other small things. I should hit around $1200 all said and done, probably a little less.
  14. #14 Re: Top Swap Pulley Options.
    Dec 2010
    Ohio
    port your tb too it takes some work to do it right but it makes a pretty decent difference when you match it up with a ported bloer and lim
  15. #15 Re: Top Swap Pulley Options.
    Dec 2010
    Ohio
    If your not going to drive the piss out of your car Wtf is the point in moding it lol and even the hd trans fail on stock cars your going to put 250hp on a trans that fails with 200hp on it, it may last a year but its going to brake
  16. #16 Re: Top Swap Pulley Options.
    Porting the blower won't do much,
    Porting the TB is a waste of time.
    You won't get past a 3.8 I'm willing to bet.
    I never did.
    Threw on an intercooler and I dropped to a 3.4, but thats the absolute limit, even with rockers.
  17. #17 Re: Top Swap Pulley Options.
    Feb 2009
    flintnasty MI
    you could probably go to a 3.2 with a s2+ intercooler on a stock cam top swap.... With decent fuel and a clean blower port.... I probably wouldnt suggest it if you are just looking for a simple setup... hell I have a 3.4 on a NIC setup here in town just because the owner doesnt race the crap out of it.
  18. #18 Re: Top Swap Pulley Options.
    GXP/gemini chain set was slightly better.
    They've seen the 12's.
  19. #19 Re: Top Swap Pulley Options.
    Oct 2011
    Kenosha, WI
    id rather pay 250 bucks for headers than zzp's togs, most people end up buying those then selling them and going for headers. Personally i think the headers are a better choice and cheaper
  20. #20 Re: Top Swap Pulley Options.
    Feb 2008
    Quote Originally Posted by RedGrandprixgt53 View Post
    Proof you have absolutely no idea what you are talking about lol. Do you know what TOGs are? The Other Guys brand headers. Arguably probably the best headers for these cars.
    I think you are mixed up with a Plog (powerlog). They are in no way the same thing.
  1. Pulley Swap MPG's
    By MyPrixGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2012, 07:30 PM
  2. top swap pulley ?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2011, 05:43 AM
  3. 3.8/3.4 pulley swap
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 02:27 PM
  4. Motor swap - Options
    By Cougar281 in forum General Tech Discussion
    Last Post: 12-03-2009, 09:52 PM
