the belt routing for the single belt just comes off the alt over the SC and down to a idler pulley on the coil bracket then down to the AC.
running one belt vs two would have less friction and parrasitic loss then two belts. but after compairing the amount of contact to the SC pulley i dont think it is the best setup. then again i wont be going with a small pulley anyway but still.
But back to the original question i have....
on ZZP's kit, is there any modification done to the coil bracket? or do you just mount an idler pulley where the tensioner is? im wondering if the belt will line up correctly. either way if i do it or not i would just like to know.
