where do you tap into for an oil pressure gauge? does anyone know if you can monitor oil pressure with a scanner? like a tech 2?
1) Necro, two years old ish
2) you remove the oil pressure switch on the oil filter adapter, dont worry, the light wont come on, GM did the OP switch all wrong...
3) You cant monitor it with a scanner unless you have an electric OP gauge and you set up the scanner to interpret the data.
4) No tech 2 can't read it in a grand prix because they came with switches, not senders.
This means that it only sends a signal when the oil pressure drops below something stupid low like 5 PSI. Kinda useless right?
5) Reiterating point one, necro, just start a new thread, people will actually be less upset if you did that.
whats an aeroforce and wideband guage
Oh wow.
GOOGLE.
wow im an idiot, i just saw 8-15 was the last post and didnt think much of it, didnt see that it was from 2008! my bad lol
All i can say is i hope my post helped you.
