Thread: Knocking
Results 1 to 20 of 30
  1. #1 Re: Knocking
    Dec 2011
    illinois
    I'll try to get it in the air but the knock is more toward the top of the engine but I should also add it didn't want to start this time around either
  2. #2 Re: Knocking
    and do you have any power loss? like does the car feel like its dogging?
  3. #3 Re: Knocking
    Banned
    CT
    Probably your knock sensor not sensing knocking enough.
    For someone who's such a 3800 god you would think that you could add information that might actually be of use to the OP.
    thats a good one. in the mean time till others check in, if you can get the car in the air, remove the plastic shield under the bell housing, then with a flash light you can see the flywheel, look for cracks, then start the car and see if it is loud, it maybe hard to see but you might see something, if its loud under there it should be a cracked flywheel.
    This. Get the shield out of the way and see if it gets louder. To really narrow it down grab a stethoscope and start checking various points of the engine/oil pan/bellhousing. I just had a flex plate go on me a few weeks ago and it sounded a lot like that.
  1. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  2. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
