Thread: Knocking
Results 1 to 20 of 30
  1. #1 Knocking
    Dec 2011
    illinois
    I was driving the car home today and it just started knocking I know your supposed to use the higher octane gas we haven't used it since we got the car but we haven't had it a month so what could possibly be wrong here could it be a knock sensor or bigger problems?
  2. #2 Re: Knocking
    post a vid if you can, could be a bunch of stuff, from cracked flywheel to dead engine, i dont think the gas had anything to do with it.
  3. #3 Re: Knocking
    Dec 2011
    illinois
    I'm uploading one to you tube now I will post link when its done my phone wont allow me to send it to my email its too big
  4. #4 Re: Knocking
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    im gonna take a shot in the dark at the flex plate
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  5. #5 Re: Knocking
    Dec 2011
    illinois
    Lord I hope not
  6. #6 Re: Knocking
    Dec 2011
    illinois
  7. #7 Re: Knocking
    Nov 2010
    Maryville, MO
    i suppose its better than a dead motor
    // 2005 Comp G
  8. #8 Re: Knocking
    Feb 2009
    flintnasty MI
    Probably your knock sensor not sensing knocking enough.
  9. #9 Re: Knocking
    Dec 2011
    illinois
    I hope it something that simple what does everyone else think
  10. #10 Re: Knocking
    thats a good one. in the mean time till others check in, if you can get the car in the air, remove the plastic shield under the bell housing, then with a flash light you can see the flywheel, look for cracks, then start the car and see if it is loud, it maybe hard to see but you might see something, if its loud under there it should be a cracked flywheel.
  11. #11 Re: Knocking
    Dec 2011
    illinois
    I'll try to get it in the air but the knock is more toward the top of the engine but I should also add it didn't want to start this time around either
  12. #12 Re: Knocking
    Nov 2010
    Maryville, MO
    hmm i would suggest gettin on the ground a seeing if its loud down there.. my buddys gtp started "knocking" and it seemed like it was in the top half of the motor turned out to be the flex plate
    // 2005 Comp G
  13. #13 Re: Knocking
    it does kinds sound like a mess up rocker, it has that clap to it. a compression test may be in order.
  14. #14 Re: Knocking
    and do you have any power loss? like does the car feel like its dogging?
  15. #15 Re: Knocking
    Dec 2011
    illinois
    Not really but I didn't want to get on it I was afraid to cause more damage
  16. #16 Re: Knocking
    Banned
    CT
    For someone who's such a 3800 god you would think that you could add information that might actually be of use to the OP.
    This. Get the shield out of the way and see if it gets louder. To really narrow it down grab a stethoscope and start checking various points of the engine/oil pan/bellhousing. I just had a flex plate go on me a few weeks ago and it sounded a lot like that.
  17. #17 Re: Knocking
    if you had a bad lifter, or bent push rod or bad rocker, it would feel weak.
    hows your oil look? is it clean, not like a milk shake? are you losing coolant, with out seeing it on the ground? if so it could be the bottom end.
  18. #18 Re: Knocking
    Dec 2011
    illinois
    Alright so I've concluded it has to be internal because there is metal flakes in the oil I am going to cut the oil filter open tomorrow to confirm this but I'm 95 percent sure I seen flakes in the oil.
  19. #19 Re: Knocking
    Dec 2011
    illinois
    I'm almost convinced its a rod knock FML
  20. #20 Re: Knocking
    Banned
    CT
    Got a video of you driving? Flexplate sounds different from rod knock when you're driving.
  1. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  2. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
