Thread: loud whistling noise on hard acceleration 2004 3.8L GTP
Results 1 to 8 of 8
  1. #1 loud whistling noise on hard acceleration 2004 3.8L GTP
    pennsylvania
    a few months ago I noticed a whistle noise when accellerating very quickly. Visually everything looks fine. Could this be a sensor, vacuum line or center head gasket???? Please provide assistance.
    GT Level Member tylerbinski's Avatar
    Canada
    It Could be a bad pcv valve - pull yours out, clean, check or replace ($4)
    I've heard this on a Gtp before
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  3. #3 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    pennsylvania
    thanks so much. I have replaced the PCVrecently since this whistle noise started, so the old one was not the issue either. Hopefully you have another suggestion. Appreciate it.
  4. #4 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    SE Level Member Hawkman's Avatar
    Jun 2010
    North east, WI
    is the sound on the right side? i have teh same issue and have checked vacume lines and i have been told it could be oil wisping in the intake just a fyi? but i wiil find out sooon when i take off my charger and see and replace all my seals and that. hope it might help!
    all stock just as the car was intended!
  5. #5 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    pennsylvania
    thank and let me know the result. Can't tell if right or left side because it will only do it under load and full throttle.This is a strange one for sure
  6. #6 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    Pull the pcv and make sure it has an o ring on the bottom of it. And that the top is sealed.
  7. #7 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    pennsylvania
    will do that today. let u know. Thx.
  8. #8 Re: loud whistling noise on hard acceleration 2004 3.8L GTP
    Pennsylvania
    Flip your DIC to the "boost gauge". You seeing boost when you accelerate? It's time for all 2004 vacuum connections to dry rot. If this is the case, check the rubber "T" under the supercharger snout connected to the lower intake manifold.
  1. 2004 GTP - hearing rather loud humming noise...............
    By msugolfer13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 03:15 AM
  2. Whining/whistling noise
    By KadenGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-19-2011, 04:20 PM
  3. Whistling Noise
    By gams in forum Introductions/Noob Questions
    Last Post: 01-05-2011, 09:51 PM
  4. whistling noise by serpentine belt
    By brookg in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2010, 05:51 PM
  5. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
