Hi everyone
New to the site been a GP owner since 2000
175,000 miles original owner
Just recently developed a whistling noise when cold can't locate source, stops when you open the oil fill or once engine is warm.
Any thoughts
Gams
Hi everyone
Any thoughts
Gams
you need to replace your PCV valve.
if youre n/a its located on the passenger side of the upper intake manifold under a cap.
if youre supercharged its located on the top of the blower under a metal cap.
if you take the valve out and shake it and it doesn't rattle then it needs to be replaced.
They're cheap to replace, under $5. Be careful while doing this when it's cold as the plastic is going to be very brittle. I've broken the plastic caps many times lol
PCV was replaced about 2 months ago.....maybe defective??
