Thread: KR after FWI install
Results 1 to 17 of 17
  1. #1 KR after FWI install
    SE Level Member wpbboy81's Avatar
    Sep 2011
    west palm beach, fl
    I had my car tuned about 2 months ago, thanks Dave, and left with no KR. well, i noticed like 1-2 degrees at WOT only at high speeds. anyways, i had an open cone at the time of tuning. i was bored and decided to do the FWI install and now i have crazy KR...up to 13 degrees. i have a scangauge II installed, i always used to look at it, but after the tune the KR wasnt there anymore, so i kinda stopped paying that much attention to it. i haven't done any mods to my car since the tune besides the FWI, so i dont know if its because of the different air intake or not. can someone please help?
    98 GTP, VS cam, SD headers, 3" full exhaust (cat/resonator/ubend deleted), genV blower, 3.4 MPS, ported LIM, open cone air filter, custom tune, alternator power cable, fuel pump rewire, AL 104s, 180 stat, flipped dog bones, 04 GTP front rotors w/ F-body calipers, and the oh so comfortable monte carlo seats
  2. #2 Re: KR after FWI install
    I live here. TLSheff's Avatar
    Simple test... put the old one back on and see if you still have the same problem.
  3. #3 Re: KR after FWI install
    Sep 2011
    west palm beach, fl
    whats funny is i didnt think about doing that until after i posted and felt dumb for posting smh
  4. #4 Re: KR after FWI install
    LOL its ok... honestly I don't think going from one open cone to another open cone thats further away will really make that difference. I would think you have something else causing the problem, but rule out the obvious first.
  5. #5 Re: KR after FWI install
    Sep 2011
    west palm beach, fl
    Yeah, im gonna have to swap filters in the parking lot when i get off work and test on the way home. i noticed like 3-4 degrees the other day but got sidetracked. on my way to work today it popped in my head again, so i floored it and it jumped straight to 13.
  6. #6 Re: KR after FWI install
    Portland Oregon
    You're getting colder air now. Your PCM pulls up to 3 degrees of timing for hot air coming in.
  7. #7 Re: KR after FWI install
    Quote Originally Posted by OH4CompG View Post
    So 3* timing = 13* KR ? ? ?
  8. #8 Re: KR after FWI install
    Sep 2011
    west palm beach, fl
    so i gotta go get it retuned when the weather changes?
  9. #9 Re: KR after FWI install
    Out West
    Weather
    Whine with your Cheese?
  10. #10 Re: KR after FWI install
    Quote Originally Posted by wpbboy81 View Post
    this is normally the case when you tune it to a certain level of 'on the edge of knock'. i always liked mine tuned more conservatively so that it didnt knock regardless of the weather.
    however, 13* of knock is a lot when it was previously < 3*.
  11. #11 Re: KR after FWI install
    Soooo.... updates???
  12. #12 Re: KR after FWI install
    Open Cone on the end of Throttle Body vs. FWI = skewed MAF readings...
    With colder weather could easily screw the tune up that much...13* though is kinda extreme...I could see 3* or so...but from what I've been seeing, you need a LITTLE bit of pipe to smooth the airflow before the MAF when running an open cone.
  13. #13 Re: KR after FWI install
    Pennsylvania
    Did you use a smaller filter? If so, that's totally your problem - you're starving the engine for air.
  14. #14 Re: KR after FWI install
    Sep 2011
    west palm beach, fl
    ok, i changed it back to just the open cone filter, and the KR dropped down to 6 now. so its a bit better.
  15. #15 Re: KR after FWI install
    Sep 2011
    west palm beach, fl
    with wat u said, i think that may be my prob. When i got tuned, i had a silicone adaptor and short pipe on the end, but when i changed to the FWI i used the stock intake hose off a 99 GP and cut it in half and clamped the pipe into it. so it went from smooth pipe, to ribbed hose, to the TB. I forgot i did make that change since the tune. I gotta find the original setup i had...hopefully its still in my trunk
  16. #16 Re: KR after FWI install
    Florida
    it was warm out when we tuned and was mid day. with the cooler air we are getting now it will throw off fueling needs add to that maf reading being diff. if you have time wednesday and want to come up we can do more tuning and dial in some tweaks in the air time spark table to better adjust for the change in temp. if you want to run the FWI then we can tune for it as well.
  17. #17 Re: KR after FWI install
    Out West
    you mean remove timing when it gets colder.
  1. Cam Install
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2011, 10:54 AM
  2. HUD and DIC install
    By rell2005 in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2011, 05:01 PM
  3. How Do I install this?????
    Last Post: 11-13-2009, 01:17 AM
  4. 04+ HUD install
    By xjyamaha in forum Audio, Security & Visual Electronics
    Last Post: 11-12-2009, 10:03 PM
  5. HUD Install
    By Rather B Blown in forum General Tech Discussion
    Last Post: 11-12-2009, 11:12 AM
