Thread: new harmonic balancer, now got KR
Results 1 to 9 of 9
  1. #1 new harmonic balancer, now got KR
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I replaced the harmonic balancer because I was getting some weird vibration comming from the engine under let's say 20 to 40% acceleration. If I went beyond that, the vibration would go away.
    Anyway I changed the balancer and retainer and it didn't quite solve the vibration issue completely. The problem now is that I've got lots of KR. Around 1 to 5 degrees that show up from 3k to 4k RPM when going WOT from a roll and past 5K RPM both from a roll and from a dig.
    I was running 20.5* of timming virtually knock free since the last time I tunned it in November. I'm not sure if this new KR happened because of the new balancer or not. I only happened to notice the KR because I tried a 3.0 pulley with the balancer change, but it gave me crazy KR, like 7* so I switched back to the 3.1 pulley but still had some KR to my surprise.
    I dropped the timming back to 19 and still seeing some of it. I did a crank CASE learn last night, but it doesn't seem to help either. Gonna check the plugs today or tomorrow to see how they look and I also checked for vacuum leaks and none were found.
    I'm kind of lost on this one. This car has historically had that werid KR issue always in which sometimes I get crazy KR no matter what timming or fueling I use and then for no apparent reason it goes away.
    I also can't hear the engine pinging when this KR shows up. I don't think I've ever heard it ping at all for that matter, I'm not sure how much KR you should have to actually hear it ping.
  2. #2 Re: new harmonic balancer, now got KR
    New or used?
  3. #3 Re: new harmonic balancer, now got KR
    Mexico
    Nevermind, the intercooler didnt have enough water for the pump to move around lmao. I bet that will give you kr XD
  4. #4 Re: new harmonic balancer, now got KR
    Ah, thats fun.
    Flow detect might be a good idea.
  5. #5 Re: new harmonic balancer, now got KR
    Mexico
    yup, the flojet pump is leaking. going to order a new one.
  6. #6 Re: new harmonic balancer, now got KR
    buy bosch?
    Or is it too late?
  7. #7 Re: new harmonic balancer, now got KR
    Mexico
    Not late yet. Theres a brand new bosch up for sale here on the for sale section.
  8. #8 Re: new harmonic balancer, now got KR
    Meziere...and the flow detect instructions are in How to. With all the part numbers.
  9. #9 Re: new harmonic balancer, now got KR
    Minnesota
    Johnson if you can find a cheap one
  1. Harmonic Balancer-no Stock??
    By diamondz101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2011, 08:18 PM
  2. Harmonic balancer pulling
    By own one in forum General Tech Discussion
    Last Post: 03-13-2011, 12:19 AM
  3. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  4. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  5. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
