Thread: Fuel pump circuit power draw car dies in 4 days
Results 1 to 12 of 12
  1. #1 Fuel pump circuit power draw car dies in 4 days
    SE Level Member 67eftw's Avatar
    Jan 2012
    Ontario Canada
    I have a 98 GTP it has a power draw that basicly kills the car in 4-5 days. I have narrowed the draw down to the aftermarket stereo and Fuel pump circuit. The Stereos draw is no serious issue, I also have a capacitor for it. The fuel pump circuit is drawing alot more power, so I unplugged my fuel pump and everything that is on the circuit under the trunk area and under the rear of the car. The power draw still persists so im clueless and I dont want to tear apart my beauty inside out to maybe find the problem. I am too lazy to unplug the fuse every time I want to drive the car, so I was thinking a kill switch. Does anyone have any advise on what to do?
  2. #2 Re: Fuel pump circuit power draw car dies in 4 days
    Nov 2011
    south carolina
    how and where are you measuring these draws? How much draw is there on each?
  3. #3 Re: Fuel pump circuit power draw car dies in 4 days
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Disconnect That DAMN Capacitor. Bud and see what happens.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  4. #4 Re: Fuel pump circuit power draw car dies in 4 days
    If you want to look for the issue. here's the fp wiring
  5. #5 Re: Fuel pump circuit power draw car dies in 4 days
    Jan 2012
    Ontario Canada
    The capacitor doesn't affect the draw whether its in the car or not. I just used a basic power tester in the fusebox under the hood, the kind with the lightbulb in the handle. I pulled the fuses out one by one to diagnose what circuit it was The stereo circuit the light is lit but not very bright. FuelP circuit that **** lights like a xmas tree. Does anyone know how to wire a kill swtich that isnt wired through the ignition? Rather from the battery to prevent power loss.
    Thanks again for the wiring pictures, I will still try to find the problem.
  6. #6 Re: Fuel pump circuit power draw car dies in 4 days
    A kill switch for the ignition or the fuel wiring?
  7. #7 Re: Fuel pump circuit power draw car dies in 4 days
    Jan 2012
    Ontario Canada
    I want to wire a kill switch from the battery so I stop losing power first, Then ill find the time to track down wiring to find the 'bad' ground or whatever it may be. I dont like carrying the FP fuse in my pocket to start my car :S
    Is this possible?
  8. #8 Re: Fuel pump circuit power draw car dies in 4 days
    Sure..I've seen some racing kill switches that interupt battery power. Check your parts stores and or summit/jegs.
  9. #9 Re: Fuel pump circuit power draw car dies in 4 days
    Dec 2011
    Cadiz, Ky
    I still dont forsee how you are figuring out the circuit draw with a simple test light. Grab yourself a cheap Digital Multi meter and Disconnect the positive terminal. Put the DMM in series with the battery and disconnected terminal. Then Set the Multimeter to the MA (Milliamp) Range.
    Another pointer is Have the battery Tested.
  10. #10 Re: Fuel pump circuit power draw car dies in 4 days
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Do what Brian said. The light test is just to test to see if there is power there. Not to rate how much power there is depending on how bright the damn light lights up....
  11. #11 Re: Fuel pump circuit power draw car dies in 4 days
    Dec 2011
    Cadiz, Ky
    And According to BillBoosts schematic The fuel pump fuse is HOT at all times. Pump is controlled by a Relay.
  12. #12 Re: Fuel pump circuit power draw car dies in 4 days
    Jan 2012
    Ontario Canada
    Ill get a Digital Multi meter to see how much is being drawn. The battery is brand new, the previous battery was swollen from freezing and it was toast. I'm only 19 and this is the only GM ive liked enough to buy, im a ford guy :P I am eager to make this car better than my 99 Eddie bauer 5.0l explorer.
  1. Can you limit power draw through smaller wire? (no, bad idea for reference)
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2010, 09:35 PM
  2. no power to fuel pump ????
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 07:00 PM
  3. no power to fuel pump ????
    By icolex1 in forum General Tech Discussion
    Last Post: 03-16-2010, 07:16 PM
  4. no power to fuel pump HELP
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 03:46 PM
  5. p0230 fuel pump relay circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-27-2009, 10:31 AM
