Thread: 01 GTP is missing in upper rev range
Results 1 to 2 of 2
  1. #1 01 GTP is missing in upper rev range
    SE Level Member tazgtp's Avatar
    Feb 2010
    California
    01 GTP is missing in upper rev range. The check engine light came on and it show po300. Had it further diagnose and it show I had a bad coil #1 and #4. Had it replace. Ran good for awhile until I started to get on it and it started acting up again. Had it diagnose and it showed po300 misfire for #1 and #4 in the history but no check engine light came on. Need help please.
  2. #2 Re: 01 GTP is missing in upper rev range
    Florida
    clear code. swap coil with another coil on the car see if the issue moves. also check plugs
  1. Trip to the range
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 02-27-2011, 05:10 PM
  2. mid range struggle
    By venge24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 03:43 PM
  3. range rover
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 07:34 PM
  4. external range sensor
    By CRAZYC in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:14 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
