Thread: let's talk custom roots blower swaps
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 21 to 40 of 212
  1. #1 Re: let's talk custom roots blower swaps
    Ohio
    yeah i see it now. umm im having no luck finding one :/
  2. #2 Re: let's talk custom roots blower swaps
    Why would you bore our block?
    Its already thin enough as it is.
    With a nice set of heads and a large NIC style cam I cant see why a tvs 1900 wouldnt work.
    Now the downside: they're slightly quieter than gen V's with much less harmonics.
    Which would push you towards a KB.
    No intercooler makes adapting the thing that much easier.
    you just need to measure a gen III from the outlet to the halfway point on the pulley.
    thats your "r" length if you were talking with magnuson.
  3. #3 Re: let's talk custom roots blower swaps
    Minnesota
    Autorotor has been done too on "Blowzilla"
  4. #4 Re: let's talk custom roots blower swaps
    Oiling issues............ mmmmmmmmmm oiling issues.
    You might be okay without dealing with them if you used an L26 front cover, polished the galleries and the oil filter adapter.
    Also run an 04+ spring/valve, 0w20 oil, run a reasonable idle speed, also look into sinister drag designs oil pan gasket.
  5. #5 Re: let's talk custom roots blower swaps
    Ohio
    ya know, im just looking for insurance might as well right? definitely change out the oil feed line. that was my plans on the engine build. get rid of the 5/8 crimp tube with the 2 90* bends in it an go for a steel braided 3/4 line with an fittings
  6. #6 Re: let's talk custom roots blower swaps
    best of luck there.
    Finding a machine shop that rebuilt a 3800 successfully is difficult.
    Ask them how many single digit turbo buicks they've built.
  7. #7 Re: let's talk custom roots blower swaps
    Ohio
    the block and heads i was gonna use for my engine build are at one now.
  8. #8 Re: let's talk custom roots blower swaps
    You sir are awesome.
    Should have waited for ZZP's new rods though.
    You should have known they were making them.
  9. #9 Re: let's talk custom roots blower swaps
    Ohio
    Matt the funny thing is, is that i never know when you're being sarcastic...lol anyways, i havent even gone through with that. Yeah I was curious about those, definitely cant wait to see how those do
  10. #10 Re: let's talk custom roots blower swaps
    First bit, serious. Second, not so serious.
    Regardless, H beam rods. Wonderful.
    If only an internally balanced forged aluminum crank was available.
  11. #11 Re: let's talk custom roots blower swaps
    Ohio
    ummm i think we strayed away from blower talk...oops, oh well we're still in the area.
  12. #12 Re: let's talk custom roots blower swaps
    bio, low compression?
  13. #13 Re: let's talk custom roots blower swaps
    Bunnell, FL
    i'm thinking the tvs 19xx or w/e it is
    as it's up there but still not ridiculous like the whipple install
    or maybe go the way of the vinnie and do an mp112 but idk if there is a write up and exactly what the custom parts list entails
    I'm a Sex Offender
  14. #14 Re: let's talk custom roots blower swaps
    91C parts....... all of the coolers haha.
  15. #15 Re: let's talk custom roots blower swaps
    Bunnell, FL
    i'm working on finding most the **** for a complete 91c conversion
    having extreme trouble on the powersteering cooler
    but they would be hella dumb if you went w/ a fmhe unless you had them mounted above the fmhe and then ran a stupid high flow fan on high most the time to make everything happy
    I'm a Sex Offender
  16. #16 Re: let's talk custom roots blower swaps
    Seriously a crank that would accept rods anything LS based would be awesome considering there are a billion options.
    2nd to do a SC setup that hasn't been done I'd be looking into a rotrex yes I know thats not engine mounted but mounts like a CSC
    3rd. Why look at other cars that have OEM SC's and find something that would work?
    Vortech makes screw type SC's now too but I have not idea what they are comparable to.
    ROTREX C38-71 Supercharger Head Unit upgrade fits BMW, Ford Mustang, Honda S2000 on eBay!
    ^^ Rotrex plus AC delete looks like cake!
  17. #17 Re: let's talk custom roots blower swaps
    Bunnell, FL
    honestly i really hate the look of the snail style supercharger
    if i had to go that route i'd go tvs 12xx and get a nice turbo
    I'm a Sex Offender
  18. #18 Re: let's talk custom roots blower swaps
    Because its not a roots blower.
    But if we're limiting this thread to roots, goodbye twin screw.
  19. #19 Re: let's talk custom roots blower swaps
    i mainly meant anything that was going to bolt directly to the motor. i already know most CSC setups are built to run stupid boost.
    the build i am going for will be low compression (stock until i blow up the block, of course) and high boost, because that's how i roll.
    knowing that troy HAD an mp112 build (that is until logan stole his adapter plate......), it shouldnt be too hard to mock up. the blowers themselves are really close in the way they are sized and the mp112 can come with a varying length snout which would make mounting and all that jazz easier when all is said and done.
    continuing on, knowing that a TVS blower is going to sound like a whisper in comparison to most blowers im basically going to skip it. others may be in this to make high power levels, i am not. this is a show and go setup, so i dont need to push 550+ whp like a whipple car would.
    the hard part for me is going to be spec'ing a blower that will allow me to get higher boost levels out of it without running straight off the efficiency map. i can always run a bigger pulley on it to back it off and keep it running well.
    as far as the motor issues with building the block: i dont care. if tons and tons of guys can push retarded power levels on the stock block (TUNE IN CHECK) then why cant i? i dont need to do any work to the bottom end until it presents itself as a problem. i planned on relocating the oil filter somewhere by the firewall and make it super easy to take on/off. the only thing i am unsure of at this point is a) headers or manifolds, and b) double roller or stock chain.
  20. #20 Re: let's talk custom roots blower swaps
    Donating Users wulfpack06's Avatar
    KCMO
    i can probably source you a cobra blower....
  1. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  2. 3800 series II Vin 1 - Pulley swaps
    By sledneck907 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 01:08 PM
  3. Let me see your GEN V swaps
    By Blown97 in forum Visual/Body Modifications
    Last Post: 04-28-2008, 09:53 PM
