have you not checked my forsale thread??
You have to ask yourself what you want to make for power.
The TVS will support boost levels up to 14-15psi without the need of an intercooler.
supposedly a local around here has vinnies old mp112 setup and is getting rid of it. why you gotta tempt meeeeee?!
MP's look sweet.
They basically offer a 15whp gain on average though... hardly worth a crap compared to just about any other mod you can spend 4 digits on. Remember that it is still going to plasma inject well before it reaches levels of "spinning too fast" to be efficent. The real trick to these eaton blowers is the fact that blower speed has little to no effect on their effectiveness to make power.
Just to recapture the OP's requirements:
You want a unique blower setup that is "loud", non-intercooled, and mostly for eye-candy with the hood open, while you care minimally about power output.
Is that fair?
i dont have a problem with a twin screw blower, which isnt considered roots. i just want to make good power (upper 300s, low 400s) without switching to a turbo.
and yes i want it to be loud.
My M90 was louder than anything.
With the silcencer ports left ALONE.
Mr. IgnorethatReptileblower.
XP Cam Start-Up - YouTube
What kind of gas will you be on?
Realistically you can run any of the TVS blowers to about 20,000 rpm if you have the flow mods to handle all the air. I'm spinning my little 1320 16,000 rpm at 6300rpm on my 2.8 and I made 350whp without heads on a relatively small cam on 93 octane through a stock exhaust.
The little 1320 would have no problems seeing high 300s, low 400s with some heads and a custom spec'd (assuming you can spec it properly) cam.
You'd likely need not spin it much higher than where I'm at.
As for how loud it is, the blower gets louder with how small the pulley is. The TVS1900 would be pretty tame the pulley you'd need to run.
Our block is pretty thin as is
Thats a pretty round number that 350whp... Conicidence!?
dont you dare start a **** fest in my thread. i will end you.
so really the concensus is that i need a blower that i wont melt my pistons while still overdriving the hell out of it so i can some stupid whine. cool.
Well according to blues video, a nice port job apparently makes it loud as hellI like it
i am going to be running pump gas. the switch to e85 may or may not be down the road farther, but for now it is a pump gas build.
Intenseracing made a blowzilla kit with a KB blower. I'd love to have one down the road. DAT WHINE.
I want to know how you make 2 pulls that seperate horsepower by 50whp? I have seen those type of pulls via a locked TC... but not by like adding 2 degrees of timing or anything.
Prob a GenV pull vs a TVS pull.
