darkhorizon
both will result in about the same end goal for power.
A ZZP pcm would work pretty darn good as is if you just bolted an intercooler on.
I think that even your most crazy cam/intercooled setups are dirt slow so I would probably suggest an intercooler over a cam as it is a pretty good upgrade for cheap. In reality, you can do an intercooler for much cheaper and easier than you can properly and reliably do a cam.
Throw some modded 1.9 rockers and headers on the intercooler setup and you could make well over 300whp.... which will also make more torque than a NIC cam, and usually it will be more horsepower than a NIC cam car makes. MPG/tuning is also better/easier.
