Thread: Which would benefit me more......
Results 1 to 5 of 5
  1. #1 Which would benefit me more......
    Aug 2008
    SOUTH TEXAS
    Right know im runing on the 3.2" with 17* timing and no kr.
    Would i benefit more from adding as much timing as i can on the 3.2",maybe 18-19*?
    Or drop to a 3.0" and run the same 17* of timing?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Which would benefit me more......
    TDCRacing
    Guest
    I think the gains would be very similar as long as you could tune for each of those.
  3. #3 Re: Which would benefit me more......
    SE Level Member Sinister Drag Designs's Avatar
    bigger pulley, more timing.
    Heat soak and parasitic loss will be less, as well as more topend power from the timing.
  4. #4 Re: Which would benefit me more......
  5. #5 Re: Which would benefit me more......
    If you can get away with it KR free I'd say up the timing...
