Thread: Serious Issues 04+
Results 1 to 20 of 26
  1. #1 Serious Issues 04+
    Nov 2011
    Bloomington IL
    I have a 2005 GTP and the only mods are a cai, axleback and bosch plugs with zzp wires. I put 4 plugs in and had a mechanic do them while my car was in the shop on the last 2 (couldnt get them out) and now its got serious misfire-like things. I think. Its struggling to gain revs under full acceleration and the exaust sounds like its coughing. Its really bad. Any ideas on whats wrong/ how to fix it?
  2. #2 Re: Serious Issues 04+
    bosch are junk plugs.
    replace with AC delco or autolite iridiums.
    NEVER use platinums.
  3. #3 Re: Serious Issues 04+
    St. Cloud, MN
    Plugs probably aren't tight or the wires are lose. Those spark plugs suck too.
  4. #4 Re: Serious Issues 04+
    Kansas
    Bosch plugs? Thats your prb.
  5. #5 Re: Serious Issues 04+
    GTP Level Member AjL227's Avatar
    IL
    Copper core Autolite's would be the best bang for the buck.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  6. #6 Re: Serious Issues 04+
    For some reason and Bosch had documented it on their site at one time, their plugs get chewed up in our waste spark ignition system very quickly.
    Take WOTGTP for example. his plugs were swapped in when he got the car from a dealer. A month later..he had misfires up the wazzooo. Swapped plugs and was a much happier camper, til his transmission died
  7. #7 Re: Serious Issues 04+
    Nov 2011
    Bloomington IL
    Got it looked at and after replacing it with some ac delcos they said the cat was causing my misfire or choking, should be under warrenty so ill let you all know whats up
  8. #8 Re: Serious Issues 04+
    Pennsylvania
    Quote Originally Posted by AjL227 View Post
    This is a lie, as anyone that can perform arithmetic can attest to. Iridium spark plugs are the best bang for the buck. Over the course of 100,000 miles, you will save both money and time.
    Coppers to get 100,000 miles: $2 * 6 plugs = $12 * 7 installs = $84 + 1/2hr labor @ $7.25/hr *7 installs = $109.38
    Iridiums to get 100,000 miles: $8 * 6 plugs = $48 * 1 install = $48 + 1/2hr labor @ $7.25/hr *1 install = $51.63
    Not to mention the couple hundred dollars (maybe $20/yr@12,000mi/yr) you'll save over the course of 100,000 miles in gas by using the more efficient plugs.
  9. #9 Re: Serious Issues 04+
    IL
    Quote Originally Posted by SlowNA06 View Post
    LOL, wow dude. You're trying too hard. It isn't a ****ing lie either.
    I apologize let me rephrase, copper cores are the best bang for your buck with a modified car that is changed often.
    People come to the forums to discuss modified cars, if your junk is stock, stick with the oem manual and gtfo.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  10. #10 Re: Serious Issues 04+
    Pennsylvania
    Hey crzystve42, guess we're not welcome here. Sorry about your stock vehicle, bro. Just trying to save my gpf speed shop homies some hassle.
  11. #11 Re: Serious Issues 04+
    Nov 2011
    Bloomington IL
    whos the little hater here? remember you were stock too *****. And the forums are for dicussing grand prix and modifications. So get youre bio-***** mess of a car out of my thread and shut the hell up. Use real fuel like a man
  12. #12 Re: Serious Issues 04+
    Nov 2011
    Bloomington IL
    whos the little hater here? remember you were stock too b*tch. And the forums are for dicussing grand prix and modifications. So get youre bio-p*ssy mess of a car out of my thread and shut the hell up. Use real fuel like a man
  13. #13 Re: Serious Issues 04+
    IL
    Quote Originally Posted by crzystve42 View Post
    Don't burst a blood vessel over the internet.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  14. #14 Re: Serious Issues 04+
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Wow maybe time to switch mechanics. It would have been better to leave the 4 in until you could figure out how to get the other two out. I'm guessing the boot cover was stuck and not the plug and your mechanic didn't want to deal with it. Still fail on the mechanics part. I bought NGK plugs and when I took out my old autolites they said NGK on them, haha.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  15. #15 Re: Serious Issues 04+
    SE Level Member timreams's Avatar
    Aug 2011
    Southwest of Pittsburgh
    i think he meant HE as in the OP couldnt get the last plugs out, so he had the mech do it while it was in the shop for something else. i could be wrong though.
  16. #16 Re: Serious Issues 04+
    St. Louis
    Not trying to be captain obvious, but have you or the mechanic verified the firing order and the plug wire order? Maybe you swapped two plug wires. If you both checked it, then check it again because it happens a lot for some reason on these cars, lol... Everyone swears that its right then they find that 2 of them are swapped after all and all is well.
  17. #17 Re: Serious Issues 04+
    Pennsylvania
    Quote Originally Posted by FordMan77 View Post
    Excellent point. If this is the case, then you've likely fouled out most of the plugs by now and will need a fresh set.
  18. #18 Re: Serious Issues 04+
    Nov 2011
    Bloomington IL
    They said the wires were too big for the plugs and they werent connected all the way. So i replaced the set with iridium ac delcos and oem spec 7mm wires. Runs perfectly now and the guy at autozone said something about Pulsar plugs that run 1,000,000 units vs the 9000 the ac delcos did. Any of that kinda true?
  19. #19 Re: Serious Issues 04+
    Pennsylvania
    Pulsars are definitely a gimmick plug (what units is this snake oil salesman talking about?), but I don't recall hearing about them causing issues - there was a thread a while back where one of our member tried them and saw a very slight increase in gas mileage, but results will obviously vary (so many factors - weather, tire inflation, etc). Basically, you've got about the best plugs money can buy already. Save the $80 and call it a day.
    Edit: We can all use a little search.
    http://www.grandprixforums.net/pulst...egit-2693.html
  20. #20 Re: Serious Issues 04+
    Nov 2011
    Bloomington IL
    Holy **** that explains a lot. Makes some sense the guy was telling me about heads with holes for direct injection that gave him 10 mpg too
  1. Having some issues....please help.
    By MarineGrunt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2012, 03:23 PM
  2. a/c issues: help please
    By us Sgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 10:33 AM
  3. hud issues
    By Iceman6669 in forum General Tech Discussion
    Last Post: 06-22-2011, 04:19 PM
  4. DLP tv issues
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 01-20-2010, 01:19 PM
  5. A/C Issues
    By ReaperRob in forum General Tech Discussion
    Last Post: 08-10-2009, 09:55 PM
