did you have no heat and then replaced the list of parts above? or is this what happened after you did all this maintenance?
if this happened before the work listed, i'd think actuator, for the blend door, if after im thinking air in the system.
grab the heater core hoses and see if both are hot, if so its should be the actuators not working. if cold, air in the system, bleed it.
Thanks for your advice,i appreciate it
