Thread: Identical l67 engines, very different power levels. Why?
Results 1 to 20 of 23
  1. #1 Re: Identical l67 engines, very different power levels. Why?
    Read the link in my signature as well, tons of info there if you haven't already.
  2. #2 Re: Identical l67 engines, very different power levels. Why?
    Nov 2011
    S Fla
    I should have clarified this part. I only meant small mods that could support later mods, in the same fashion as removing the u-bend. No real power gain by itself, but it helps with later mods. I don't know if there will be any similar things to do while the top is off, and I don't want to have to take it apart twice.
    I've read through the "safely modding" thread and learned quite a bit. That thread stopped me from buying a pulley right away. I'll do all the supporting things first + a tune (maybe) and see what I've got. If I still want more, then I'll consider going further. I read in one of the threads that you can get into the 13s at sea level without a pulley. Don't know if it's true or not, but it goes to show there's a lot pf power already in these engines without really adding anything to them.
  1. How hot are l67 engines supposed to get?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2010, 09:02 PM
  2. What vin 1 engines.....
    Last Post: 06-16-2010, 08:03 PM
  3. Coolant levels
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2009, 10:27 PM
  4. Jasper Engines....anyone know anything about them?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 08-13-2008, 04:23 PM
  5. what is the difference between member levels.
    By s1795so2 in forum Off Topic Discussion
    Last Post: 01-11-2008, 06:05 AM
