machinegunsquid
Sparkplugs, the obvious answer!
Pull 1 or 2 plugs on each motor, and see how they look. Old worn out plugs, or misgapped will make a huge difference in power, especially if they are experiencing blowout.
Just a thought.
2nd would be fuel/cat conditions.
If you could, get an Aeroforce scan gauge, and go ahead and hook the powerwire to an add-a-fuse, so you can hook it up/take it off in a matter of seconds, so you can
A: pull any SES codes
B: Check knock
C: know much more about the condition of the engine
Plus, if you're going after an L67, you'll want an Aeroforce anyways =]
