Thread: Okay, aparently I'm and idiot. Gen V help
Results 1 to 17 of 17
  1. #1 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by VinnieGTP View Post
    Check the BBV operation.
    When the car is off is it all the way down at the 9:00 spot? When you start it does it go all the way up to the 12:00 position? When you hit the throttle cable on the TB does the BBV move smooth?
    Video looks like you're just recovering from bad wheel spin and thats why the speedo is hesitating like that.
    If it doesn't do to the 12:00 position at idle theres an issue. Does it close again when you blip the throttle? Can you gently manualy move it to the 9:00 position with the car off?
    Well I checked once I pulled in just a few moments ago. At idle it is in the 12 O'Clock position, and when I blip the throttle it moves. I did'nt rev it up all the way or anything though, but it seems to be working correctly.
    why are all of your dummy lights on... on dash
    Multiple reasons why those are all blinking, nothing to do with the current problem though.
    And that is the Security light blinking, not the SES light.
  2. #2 Re: Okay, aparently I'm and idiot. Gen V help
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Have you pulled your plugs to see if you have popped a piston? I ran a smaller pulley than I should have once... I kept popping chunks off the top of the piston and the debris would smash the plug to where it would only run good at higher RPM's... If you did... it would most likely be piston 4 or 6... Those are the ones I always had problems with... Just a thought...
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  1. I am an idiot
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-07-2008, 07:52 AM
