hey is there any how to on changing the bbalance shaft bearings on gtp in the car? what kind of special tool are required for this? need to know . thanks guys
steph
steph
Again, that sir is your balance shaft. You'll need to pull the crank pulley, then the front timing cover.
Only special tool is the pulley puller it's self. Then remove the gear from the end of the balance shaft, and put it back together.
That's the simplest way.
If you want to do it the 'right' way, then you'll have to pull the motor, remove the entire balance shaft, and drill/tap the oiling holes, but there's just no need for that, unless you're going for a full out rebuild.
Ok soo once i pull the gear off the shaft it should slide out the side enough to change the bearing? And also wen i put it back togethor does it need to be timmed of just slap the chain on it? Ill be doing this tonight soni need as many answers possible thanks for the help and sorry bout mis typo..![]()
And do i need the balance shaft? Wat do u mean just delete it .. Please explain on how i would delete it thanks![]()
What he means is just remove the gear the drives it and let it stay in there. I don't recall if you have to take the timing sprockets off to get to that gear but if you do, remember those bolts are torque to yield so they need to be replaced. You'll need a new cam bolt and crank bolt
Okay but i have a bottom end of a gt grand prix with a gtp connecting rod on one piston soo i have 5 connecting rods that are gt and one gtp and gtp ones are bigger... Inconclusion wen i remove the balance shaft wont my crank be very unbalanced due to the one connecting rod bigger on one piston?
To funny. Another cool idea is to use a l36 for one head and a l67 for the other head
Guys.. At the time i dint have cash soo i had to do for my wheels back and i have the same compression in all 6 pistons so relax. Anyone wanna feel free to answer my question or no?
To change the cam bearing the procedure says you remove the crank. then you can get to the cam bearings. It may be possible to do it with the crank in. However if you pull any lower end bolts, please keep in mind they are TTY and GM says we should not reuse them.
There is a speical tool, I was not able to find one to rent anywhere.
FWIW, if you are doing cam bearings, let a shop do them. Sometimes even if they are driven in correctly, you may need the bearing honed to fit the cam. Been there, and done that.
