Thread: snout bearing replacement
Results 1 to 17 of 17
Threaded View
RICE KILLER snout bearing replacement 08-10-2011, 09:47 AM
WHT98GTP Re: Has anyone replaced the... 08-10-2011, 10:22 AM
RICE KILLER Re: Has anyone replaced the... 08-10-2011, 10:40 AM
GR8racingfool Re: Has anyone replaced the... 08-10-2011, 12:06 PM
WHT98GTP Re: Has anyone replaced the... 08-10-2011, 11:57 AM
txslow6 Re: Has anyone replaced the... 08-10-2011, 12:02 PM
WHT98GTP Re: Has anyone replaced the... 08-10-2011, 12:15 PM
BillBoost37 Re: Has anyone replaced the... 08-10-2011, 12:45 PM
txslow6 Re: Has anyone replaced the... 08-10-2011, 01:04 PM
RICE KILLER Re: Has anyone replaced the... 08-10-2011, 01:16 PM
BillBoost37 Re: Has anyone replaced the... 08-10-2011, 01:23 PM
GR8racingfool Re: Has anyone replaced the... 08-10-2011, 02:10 PM
RICE KILLER Re: Has anyone replaced the... 08-11-2011, 07:55 AM
GR8racingfool Re: Has anyone replaced the... 08-11-2011, 02:08 PM
RICE KILLER Re: Has anyone replaced the... 08-11-2011, 02:57 PM
TheOtherNick Re: Has anyone replaced the... 08-11-2011, 08:52 PM
GR8racingfool Re: snout bearing replacement 08-13-2011, 09:47 AM
  1. #1 snout bearing replacement
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    I have searched everywhere for info on rebuilding my gen v snout and the only thing I can find is info on the gen 3. Im not sure if they are the same. All I need to know is how to safely get the shaft out of the snout casing and I should be able to get it from there. For the gen 3 I read that you just tap the shaft fron the pulley side and the shaft will come out with the bearings. I tried this and the shaft did not budge, what is the best way to get that shaft out? Thanks in advance.
    2000 Daytona Pace car, SD Hood, Xp cam, Ported Heads, Gen V, North Star, Headers, ZZP stage 2 Intercooler, 3in Exhaust, and custom tune
  1. Snout seal replacement.
    By Deno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2020, 09:00 AM
  2. Supercharger Bearing Replacement!!
    By Motter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:23 AM
  3. Wheel Bearing Replacement. Question!
    By brownb66 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:04 PM
