Quote Originally Posted by wpbboy81 View Post
Ok, i did some research and according ZZP the LQ4 is popular because as they quote "
The LQ4 maf is cheap, and easy to replace if you ever need a replacement. It cross references to many different applications.
". i looked on autozone's website, and the 00-05 northstar engines use the same MAF part number as the 99-2000 6.0 engine chevy trucks. sooo, i'm guessing i can use the MAF from the caddy then
^^good work! this helps me out too
