Thread: First Port&Polish attempt
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 First Port&Polish attempt
    SE Level Member logan809's Avatar
    Sep 2011
    Kansas
    I was doing an LIM gasket and decided i would port and polish my SC while i had it off. heres some pics
    right after rotor removal:
    after rough cleaning of rotor walls:
    before port:
    after port and polish completed:
    1997 Grand Prix GTP
    Ported Gen 3, Ported TB, FWI
  2. #2 Re: First Port&Polish attempt
    Feb 2009
    flintnasty MI
    And, you now have a paper weight!
    You cant touch the walls of the blower... there is a -.002 interferance with the case, it is what creates the seal that keeps boost in your motor.
    Someone probalby has a new blower around here for around $100.. so it shouldnt hurt too bad.
  3. #3 Re: First Port&Polish attempt
    I live here. TLSheff's Avatar
    I saw first attempt at Porting and Polishing and got all excited... and you did well for first try on porting.
    Some waviness I can see that could be touched up, and more rounding could be done... but not bad
    As far as polishing, you did well, except for like darkhorizon said... there is a very small gap for cleaning, and the EGR would just make it all dirty again by the time your engine warmed up to proper operating temp, which is why nobody worries about the inside. Its not like anyone would see the inside anyways. Polishing the supercharger usually refers to the outside casing.
    Nice work tho
  4. #4 Re: First Port&Polish attempt
    FWIW I advise not to clean the inside area where the rotors sit. Becuase of the clearance issue. The bigger gain could be had at the inlet end and smoothing the roughness.
  5. #5 Re: First Port&Polish attempt
    Florida
    OUCH... that blows man. the rotor pack wears to the case anyway. im not a fan of swapping cases as i feel this could result in a bad seal too. like said if you sanded the walls of the case it is time for a new blower.
  6. #6 Re: First Port&Polish attempt
    Sep 2011
    Kansas
    Quote Originally Posted by Z34Phoenix View Post
    Didn't sand them at all...just polish..
    1997 Grand Prix GTP
  7. #7 Re: First Port&Polish attempt
    Air density has a lot to do with it. It's cooler and therefore more dense air as well.
  8. #8 Re: First Port&Polish attempt
    you shouldn't have touched the insides, like the others above have said. you may have just screwed yourself over and ruined the case.
  9. #9 Re: First Port&Polish attempt
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Should have done some research before taking the die-grinder to it:
  10. #10 Re: First Port&Polish attempt
    Sep 2011
    Kansas
    Haha whatever you guys say...haven't lost a bit of boost so I'm really not too worried about it.
    1997 Grand Prix GTP
  11. #11 Re: First Port&Polish attempt
    You going by an actual reading or the Giant Pile tinker toy block sticker looking boost gauge?
    Regals have a digital numeric readout. In case one of you guys I'm normally picking on is wondering.
  12. #12 Re: First Port&Polish attempt
    Quote Originally Posted by logan809 View Post
    I imagine you feel like you didn't lose any boost, but really you did. Porting the outlet should have allowed more air to be pushed into the LIM thereby giving the engine more power. You don't notice any loss because you killed pressure with the polishing, but upped the outlet so you countered your own modification. You have a ported blower that might be performing like a stock blower, grats
  13. #13 Re: First Port&Polish attempt
    Orange County, NY
    Is it wrong that I can't stop lawl'ing over this comment!!?!?!?!
    Bwuah hahahahhahhaa!! I love it!!!
  14. #14 Re: First Port&Polish attempt
    Florida
    well... opening the outlet would have allowed more boost and polishing the walls would have lowered it... the outlet looks great. you may have a net gain. but still lost some from polishing the walls.
  15. #15 Re: First Port&Polish attempt
    And no, opening up the OUTLET lowers boost levels...more flow.
    Less heat, less parasitic loss, less restriction.
  16. #16 Re: First Port&Polish attempt
    IMMABOOSTIN' muh LEGO'S!
  17. #17 Re: First Port&Polish attempt
    Sep 2011
    Kansas
    I guess ill make myself look like a dumbass and say giant pile tinker toy guage. Alls I know is it never maxed out until now.
    1997 Grand Prix GTP
  18. #18 Re: First Port&Polish attempt
    Probably because you fixed a vacuum leak somewhere.
  19. #19 Re: First Port&Polish attempt
    Sep 2011
    Kansas
    I fixed all vacuum leaks weeks before I did the LIM gasket and didn't change.
    1997 Grand Prix GTP
  20. #20 Re: First Port&Polish attempt
    I lost about 2-3psi according to the real gauge in my Bonne when the coating got stripped off the rotors (long story abotu TB cleaner).
    You probably lost a pound or so.. power will still feel pretty good and well.. I think maybe you could buy a sticker that shows a maxed out block toy thing.. or glue some legos there. Remember go with red and yellow blocks only. Green don't match well.
  1. Supercharger Port & Polish
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2011, 11:24 AM
  2. Car will not attempt to start and keys get stuck...
    By Levi in forum General Tech Discussion
    Last Post: 02-01-2011, 11:24 AM
  3. 4th attempt. Hopefully a better turn out.
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2010, 07:06 PM
  4. Going to attempt the Digital DIC swap! Who's done it?
    By Blacknight02GT in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2009, 12:19 AM
  5. Port and polish
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2008, 02:57 AM
