Thread: spark plugs from autozoe
Results 1 to 18 of 18
  1. #1 spark plugs from autozoe
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    what are some good spark plugs from auto zone with 3.4 pulley, cai, slp exhaust, and ubend delete?
  2. #2 Re: spark plugs from autozoe
    Autolite 104's
  3. #3 Re: spark plugs from autozoe
    Charles City, IA
    ^ what she said.
    SMGPFC Two Nipple General
  4. #4 Re: spark plugs from autozoe
    PA
    Autolite 104's
    Yup.
    2001 GSE
  5. #5 Re: spark plugs from autozoe
    gapped to .05-.055
  6. #6 Re: spark plugs from autozoe
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Say he went with a 3.6 stock would be good right?
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  7. #7 Re: spark plugs from autozoe
    I'd scan it too and probably save some money up for some headers.
  8. #8 Re: spark plugs from autozoe
    Omaha, NE
    Quote Originally Posted by chevyy1212 View Post
    Correct. Colder plugs aren't reccomended until 3.4 because too cold of a plug will foul.
    Depending on the car, a 3.4 setup won't need 104s.
  9. #9 Re: spark plugs from autozoe
    Jun 2011
    Middletown, NY 10940
    Not sure if it needs mentionong but copper
    Daily Regal GS
    Weekends Spyder GST
  10. #10 Re: spark plugs from autozoe
    I'd be buying new spark plugs just because you probably don't have the flow mods to safely run a 3.4"...but its wuteva.
    Quote Originally Posted by TeacherCreature View Post
    That's what 104's are.
  11. #11 Re: spark plugs from autozoe
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    AC Delco thats what was made for the car and thats what works best
  12. #12 Re: spark plugs from autozoe
    Portland Oregon
    Quote Originally Posted by asite57 View Post
    Apparently you haven't modded boosted cars before.....
  13. #13 Re: spark plugs from autozoe
    Jun 2011
    autolite makes a platinum 104 (ap104)
    To the original poster make sure it is copper
    Daily Regal GS
    Weekends Spyder GST
  14. #14 Re: spark plugs from autozoe
    Jun 2011
    To the other guy ac delco does make an equivalent plug to al104 not that I think they r best cause factory used em but his preference also doesntean he hasnt worked on boosted cars either... Use a cross referenve chart (google)... Al104 r popular the ngks are popular too... The importance here is copper and heat range ... Much more so then brand.. Hope that helps...
    Daily Regal GS
    Weekends Spyder GST
  15. #15 Re: spark plugs from autozoe
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    FAIL!
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  16. #16 Re: spark plugs from autozoe
    Kansas
    If you ask Nick or Brian, spark plugs from Autozone must make your car faster because they say Nascar on them.
  17. #17 Re: spark plugs from autozoe
    May 2011
    Kansas City
    Quote Originally Posted by NegativeOne13 View Post
    Just because it says Nascar doesnt make it fast....only means its more likely to increase the amount of poon you get because you now have racecar
    Reptile Tune (SOLD)
  18. #18 Re: spark plugs from autozoe
    Kansas
    Quote Originally Posted by SerenityGTP View Post
    You wouldn't get it Cody..... CAUSE YOU WEREN'T THERE!
  1. Spark Plugs on '04
    By 04GT2 in forum General Tech Discussion
    Last Post: 08-10-2016, 12:34 PM
  2. spark plugs
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2013, 03:34 AM
  3. Which Spark Plugs Should I Run?!?
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 08:27 PM
  4. What spark plugs should I get??
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2010, 11:13 PM
  5. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
